Apr 11, 2011, 11:45 AM
HawkSky Gyro
Just ordered a HawkSky. I heard a Gyro can be added to the ailerons to increase stabillity. Any model gyro recommended or any howtos?
Apr 11, 2011, 12:00 PM
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
There are lots of threads on RC Groups that deal with the use of gyros on fixed wing planes. https://www.rcgroups.com/forums/show....php?t=1035605
Apr 11, 2011, 04:07 PM
Where can a gyro be purchased at? I see esky 704 etc listed as options.
Apr 11, 2011, 05:10 PM
Gerry__'s Avatar
Dirt cheap on ebay.
Apr 12, 2011, 02:56 AM
Originally Posted by Gerry__
Dirt cheap on ebay.
http://cgi.ebay.com/Eflite-G110-GYRO...item3f09039c07
will that work with the hawk sky?
Apr 13, 2011, 12:52 PM
Ant
Ant
Old Noob.
Ant's Avatar
From what I am led to believe, you want a rate gyro, not a head lock gyro.
I do not know what kind the gyro is that you posted is.
They should say what type they are in the description, so you may have to find the manual online for ones that you are considering purchasing.
Apr 13, 2011, 01:59 PM
I ended up buying the 704, although the head lock would be pretty cool also. From what I understand, if it is initialized properly, it will return the plane to flying horizontally if you let go of the aileron control stick. Someone in another thread said it wouldn't work with the stock rx/tx so I decided to just get the 704 since I know it will work.
Apr 13, 2011, 02:38 PM
Ordered this one:
http://www.nitroplanes.com/ek2-0704.html
Hope it works?
Apr 13, 2011, 02:47 PM
Gerry__'s Avatar
Ordered this one:
Hope it works?
It's a rate gyro so it will work fine.
Apr 13, 2011, 05:45 PM
Ordered this one:
Hope it works?
yeah that's the one I ordered. Threw a 1800mAh 15C lipo in the cart to get free shipping.
Apr 14, 2011, 06:59 PM
FPV Browncoat
prelator's Avatar
The 704 gyro seems to be the best one for the Hawk Sky. I put one on my Hawk Sky and it definitely helps flying in wind. My maiden flight was in 15-20mph winds and I quickly lost control of the plane. With a little more experience and the gyro, I can now fly in 20-30 mph winds, though at that speed the stock motor can barely make headway directly into the wind.
Here's a video I found on how to install the gyro in a Hawk Sky:
Hawksky gyro install with Esky 704 gyro (14 min 21 sec)
That's what I did, though ignore the part about the plywood and the special tape. I just hot glued the gyro directly to the foam block, which in turn was glued in right over the wheel well in the back of the nose (make sure not to shove the landing gear into its mount too hard though--once I accidentally shoved it straight through the fuselage and dislodged the foam block with the gyro on it). The video is right, about 30% clockwise turn on the dial should be about right for the stock aileron configuration. I recently doubled the size of my ailerons and noticed the gyro seemed to be overcompensating because the plane was bouncing around constantly in any wind. Today I tried flying with the dial around 15%, and even though winds were much calmer, it produced a noticeably smoother effect in my on board video footage.
Apr 22, 2011, 01:06 PM
Regarding a rate gyro in a Hawk Sky, the 704 will fit on the bulkhead below the hatch
magnet and not interfere with the hatch fit. Will the gyro performance be affected by the
gyro being close to the receiver and the hatch magnet? The gyro functions in that position
but unsure how well it will work in flight. Will appreciate all replies and input.
Thanks, from Brookings Oregon
Apr 22, 2011, 01:15 PM
FPV Browncoat
prelator's Avatar
Personally I prefer the setup shown in the video I posted mounting the gyro on a foam block on the little ridge above the landing gear mount. It's less in the way there, and it's also perfectly vertical that way while if it was on that bulkhead it would be slightly slanted. I doubt it would affected by the receiver no matter where you put it, though I have no idea if magnets affect gyros or not. You may just have to test it and see.
Apr 26, 2011, 07:16 AM
Team Wack-a-Mole
Melnic's Avatar
There is a link to a list of gyros and comments on this gyro help page
http://www.mycoolrc.com/gyro/indexnew.html
Apr 26, 2011, 06:16 PM
Are there any smaller rate gyros available?
Discussion Hawksky modes I made and why Radstick Parkflyers 1 Mar 24, 2011 01:56 PM
Help! hawksky RC plane Jimsniper Beginner Training Area (Aircraft-Electric) 3 Jun 17, 2009 08:55 PM
Discussion Dynam HawkSky realjumper Foamies (Kits) 2 Jun 04, 2008 03:28 PM
