This thread is privately moderated by Zaitsevsky, who may elect to delete unwanted replies.
Apr 04, 2011, 12:57 AM
Zaitsevsky's Avatar
Mini-HowTo
A servo with an IR horizon sensor for camera mount
A servomechanism with a horizon sensor. Can be used on a camera gimbal or an aircraft.
A servomechanism with a horizon sensor (0 min 12 sec)
Such a servomechanism is usable for controlling the bank of the aircraft or the inclination of the camera. You'll be able to control the inclination of the camera; the neutral position will conform to the horizon line. In addition, it is possible to control the ailerons of the aircraft and to incline the aircraft to the desired angle in respect of the horizon. If the horizon line is not symmetric, a bank of the aircraft appears. The scheme of the sensor:
PCB:
IR photocells are fixed on the movable part of the controlled gimbal of the camera or on the opposite ends of the controlled model. A signal of the sensor is applied to an ordinary servomechanism instead of the internal potentiometer. The potentiometer of the servomechanism is connected to the negative terminal, to the reference voltage and has one output (3 conductors); the infrared sensor is connected in the same way.
Sold AP-2000i with FMA IR Sensor $100 shipped Breezemont Aircraft - General - Miscellaneous (FS/W) 4 Dec 10, 2010 06:40 PM
Question Camera mount (GoPro and FPV camera) on a servo? rclab1 FPV Talk 1 Nov 12, 2010 01:51 PM
Discussion Servo jitter with ir sensor techspy Revolectrix 4 Feb 26, 2010 12:43 PM
Sold For Sale - Spartan ap2000i with IR sensor $200 shipped Aobid Aircraft - Electric - Helis (FS/W) 2 Apr 03, 2009 01:42 PM
Discussion FMA Co-Pilot/Where to mount the IR Sensor nz-maori Aerial Photography 14 May 03, 2007 04:53 AM
