Apr 03, 2011, 11:27 PM
**neons**'s Avatar
Build Log
Scratchbuilding a Japanese Kawanishi H8K2 "Emily"
I have started to build a large Emily and have posted the started plane in Scratchbuilt Foamies Forum.
https://www.rcgroups.com/forums/show...4#post17872340
**Neons** Bob
May 31, 2011, 03:12 PM
**neons**'s Avatar
All Parts Made and just Temp Put together as a Mockup
I think I am maybe 3/4 done on the construction of the plane. All the major parts are made and just stuck together to look at it. It is in the above link started around April Fools Day 2011.
If you like home made aircraft, have a look at the assembly so far. The latest is the servos are all operational and I ran the motors. I am waiting upon 3 more APC props also. I may vacu-form some parts later too as time allows.
**Neons** Bob
Jun 02, 2011, 06:30 AM
Registerd Beaver
Smokin' Beaver's Avatar
Oooh nice one Bob.
I studied all the Jap flying boats before building my Mavis.
I'll go & have a look at the build.
Phil
Jun 02, 2011, 08:32 AM
**neons**'s Avatar
Hi Phil. Thank you for the big praise for posting another beauty . I like your model very much. It looks like it is a harder model to build as there are many compound curves on the plane.Setting up the wing struts is also demanding. Once she has all the markings on the plane it will really stand out beautiful. Isn't it great to be able to have a plane that kit manufacturers do not produce? I have seen one other Mavis flying I think in the RC Groups. Good luck on your flights.
**Neons** Bob
Jun 09, 2011, 01:13 PM
**neons**'s Avatar
Yesterday I ran the motors and controls for the first time. The only problem I had was the motor mounts kept loosening the set screws. I replaced them with socket screws and a jam nut with some Loctite. I have the videos posted in Webshots which is fair quality and size and good quality and full screen in Vimeo. The motors put out some good thrust.
Motor specs. Hextronic DT-700 and 750's. 2 each. The battery is a Turnigy 5000mah, 40-50c rated and the cells are 4S with 14.8volts. The props are APC 4 blade 10x6 pitch.
The motor thread is here:
https://www.rcgroups.com/forums/showthread.php?t=777998
The Webshots videos Here: (over 80 others also)
http://good-times.webshots.com/video...ost=good-times
The best quality is at Vimeo Here:
(2 min 7 sec)
**Neons** Bob
Jun 25, 2011, 10:10 PM
**neons**'s Avatar
I added some more pics to my build log. I am almost done with the build. More pics and info at the build link above in the first posting.
**Neons** Bob
Jun 26, 2011, 12:45 AM
Speechless.
Bob, she is beautiful............
federico
Jun 26, 2011, 09:50 PM
**neons**'s Avatar
Thank You Tochiro,
I wanted you to see her as it comes together. If you go to the Vimeo video pages in the website above have a look at my others. There is an Albatros and a real nice Me-109G-6 I scratchbuilt also in there. The build logs links are under the movies.
**Neons** Bob
Jun 29, 2011, 12:34 PM
Wow, that is an amazing build. Almost too pretty to fly.
Jun 29, 2011, 02:12 PM
**neons**'s Avatar
Thank You. I know. But, it has to fly as I built it for an Annual Waterfly Event later this year. Stay tuned as it progresses. I will have some video as it goes on.
**Neons** Bob
Jun 30, 2011, 03:33 PM
**neons**'s Avatar
Just put up some more daylight shots on the grass today June 30th 2011.
https://www.rcgroups.com/forums/show...417974&page=10
Enjoy.
**Neons** Bob
Jul 08, 2011, 03:29 AM
AMA 670207
Rudderman98's Avatar
Well done Bob!
She's a beauty. Video soon??
Jul 08, 2011, 07:02 PM
**neons**'s Avatar
Thanks Rudderman. I hope to do some taxi tests Monday. i will post if anthing good comes of it.
**Neons** Bob
Aug 13, 2011, 12:16 AM
**neons**'s Avatar
After all the work going into the model creation I finally did the maiden today after 2 failed tries. I had to install beefier motors and it was all run off without a hitch. I can say it is complete now.
(5 min 36 sec)
**Neons** Bob
Aug 13, 2011, 01:32 AM
AMA 670207
Congrats on your maiden Bob.
Well done!
Perry
Build Log Kawanishi H8K2 "Emily" Flying Boat **neons** Foamies (Scratchbuilt) 229 Aug 16, 2018 08:57 AM
Build Log Kawanishi H6K Mavis Smokin' Beaver Electric Warbirds 47 Aug 11, 2018 03:37 PM
Discussion Japanese Zero fighter sugat_805 Fuel Plane Talk 5 Sep 01, 2010 09:42 AM
Gallery Japanese Kawanishi H8K Akentut General Aviation 1 Aug 16, 2010 06:49 PM
Video Kawanishi H6k peterangus Electric Plane Talk 5 Oct 27, 2006 03:46 AM
