May 12, 2019, 10:06 AM
FlyerMan4Life's Avatar
Originally Posted by Saxguy1000
Pretty amazing.
first 2 in a row were 102mph after that it faded off but best to date ....I might try an apc 9x9 and possibly a 10x10. the power 25 handles the aero-naut 9x9 carbon no problem.... comes down cool everytime and now with a 60amp esc I have some head room.
May 12, 2019, 11:58 AM
I just ordered the aero-naut 10x10 carbon....ive had good luck with them ....they are pricey but speed is the goal and test show a gain in rpm with less draw for the same thrust and speed as apc props.
May 12, 2019, 01:49 PM
Hi,
I have many, many flights on a E-Flight Advance 25e powered by a Power 25 870 KV motor on 4S 4500 HV 40C batteries, a 60 amp ESC, and a APC 11X10E prop. I would think the 10X10 would work just fine.
Good luck!
May 12, 2019, 03:04 PM
I have the 1250kv motor so your 870kv could handle a larger prop with ease
May 14, 2019, 01:49 PM
the 10x10 carbon should be here by tomorrow....weather is garbage up here in NY so hopefully I can test on of these evenings ....Il run it up on the watt meter anyway....9x9 is making 930watts about 55amps right now on 4s.
May 16, 2019, 08:04 PM
10x10 is mounted up and ready for radar test tomorrow!
update: 10x10 was too much prop.... I figured I was maxed out where I was anyway but glad I ran it up on the watt meter first!
1375watts @ 93amps wide open with 4s 2400mah lipo HV ....after only 2 consecutive 4 second pulls it was getting in the danger zone....the little power 25 is tuff but not that tuff for back to back speed runs it would burn up for sure!
...with the new battery and same 9x9 prop its pulling more than last season 1050watts still at 63-65amps which you can drag on it all day even static nothing more than luke warm motor and esc both ....looks like the max power to efficiency window is met.
Jun 23, 2019, 04:00 PM
Creative RC's Avatar
Rudder extension
As an experiment, decided to extend the rudder. The extension can be easily removed as it is attached with strips of scotch tape. Will advise on flight performance.
Next time I go out will take some GPS speed readings with 3s and 4s batteries with the Power 15 setup and will advise. Very fun to fly on 4s.
Jun 26, 2019, 07:42 AM
that looks good ! will be interested to compare speed with your power 15
Sold 3DHS 41" Blue Edge NIB + Eflite 480 Cabledawg1 Aircraft - Electric - Airplanes (FS/W) 5 Sep 03, 2010 12:58 AM
Question Thoughts on the Ultrafly P51D w/ Retracts lafuerza Electric Warbirds 3 Sep 01, 2010 02:16 PM
Discussion Should I try high Timing on a Eflite 480? Cabledawg1 Power Systems 4 Jul 19, 2010 01:16 PM
Discussion Can't replace shaft on Eflite 480? Lowezz Electric Motor Design and Construction 6 Apr 07, 2009 10:42 AM
Any thoughts on airfoil for 400/480 stuka with scale wing kit basher Power Systems 3 May 19, 2001 11:21 AM
