Jul 25, 2017, 07:36 AM
ARFs Are Me
TomCrump's Avatar
Originally Posted by kingsflyer
Thanks for the pictures. I thought you were referring to the small plastic fairing next to the fuselage. My bad.
McD
I thought the same thing, until I saw the pics.
Jul 25, 2017, 08:31 AM
gregoryshocc's Avatar
Tom's fix is the best approach for your problem.
McD
I contacted Great Planes. It sounds like they are going send me new landing gear. Everyone including Great Planes thought I was referring to the small plastic fairing next to the fuselage. Then I started posting and sending pictures. I didn't know what to call the things that were cracking. The word "fairing" was the best I could come up with.
Jul 26, 2017, 06:52 AM
We shall serve the Lord
kingsflyer's Avatar
Glad the Great Planes Customer Service folks were able to take care of your problem.
McD
Latest blog entry: LEDs on my T-28
Jun 04, 2019, 11:52 PM
Construction advises
Hello All
I just got a GP Waco and will start assembling it soon!
I was reading this review/forum and another forums as well and I'm going with the DLE20RA as the engine.
Kingsflyer, I would like to ask ig you have some clearance between the engine and the cowl? The DLE20RA is 3mm higher that the DLE20. This is a minor difference and I hope I wont need to cut more of the cowl than the aperture for the spark plug as you did.
Also, what size of tank you are using?
Thanks a lot!
Jun 06, 2019, 01:35 AM
kingsflyer's Avatar
I used the provided tank that came with the kit. I just changed the stopper to a gasoline stopper.
The only reason I mounted my DLE20 on its side was that my original installation was for the AX95 that was side mounted. If I were starting my build from scratch, I would mount the DLE20RA with the head facing straight down like they show the DLE30 in the instructions.
McD
Jun 08, 2019, 01:43 PM
Hello
I have another question.
I saw in different posts that some had problems with the aluminium brackets that broke over time.
In the upper wing, after assembling it, there will be no access to change the brackets if I'm understanding the manual correctly.
How do you manage to change the brackets of the upper wing after it is assembled?
I'm adding a pic to show the issue I'm talking about.
Thank you for your patience
Jun 08, 2019, 02:18 PM
McD
Thanks for your reply! Yep, this is what I'm planning to do.
Cheers!
Jun 09, 2019, 04:05 AM
kingsflyer's Avatar
I never had any problems with the brackets that were glued between the wing sections nor the ones on the fuselage cabane struts. The brackets that failed were on the interplane struts on the outer wing panels.
Jun 09, 2019, 02:16 PM
That is good to know! Thanks!
Discussion Great Planes Waco YMF-5D Biplane ARF .91-1.20 jonnyspeed Glow to Electric Conversions 23 Apr 30, 2012 05:51 PM
Sold Great Planes Seawind ARF 60-91 NIB LPU San Diego 235.00 boatdoc Aircraft - Fuel - Airplanes (FS/W) 0 Mar 09, 2011 12:07 AM
Sold Pica Waco YMF-3 Biplane 60" Wingspan. $75! Johnny Angel Aircraft - Fuel - Airplanes (FS/W) 6 Dec 27, 2010 04:50 PM
Sold Great Planes P-6E Hawk biplane ARF nutzaboutharleys Aircraft - Fuel - Airplanes (FS/W) 3 Dec 17, 2010 09:01 PM
Sold Pica Products 1/6 Scale YMF-3 Waco Biplane - Unassembled Kit in Box szastoupil Aircraft - Fuel - Airplanes (FS/W) 2 Jun 26, 2007 12:25 PM
