How much heat can Corrosion-X handle? And can it be wiped off easily?
Two questions.. Simple enough.
Now here's the long version: I'm about to do my first application of corrosionx. I got the 16oz squirt bottle which I am going to dump into a mason jar. I plan to submerge my ESCs, RXs, and servo driver boards in the liquid and leave them there for a day or so (based on other things I have read). I will agitate the liquid from time to time to eliminate bubbles. The RX is easy, I will remove the case and submerge it. Once I remove it I will allow it to drip dry and then put it back in it's case. The Servos could be a little bit of a challenge. I think I only want to get the circuit board treated, maybe not the whole servo. I'm open to input though. Finally is my ESC. I have two Turnigy Plush ESCs that I will be doing. I have the option to remove the heat shrink and then put new heat shrink on after the corrosionx is applied. I already have the heat shrink so it's no big deal. Or I could just plop the whole thing in there without removing the heat shrink. When I put the new heat shrink on the 80a ESC it will be a tight fit. I wonder if I will rub the corrosionx off of the ESC? Also when I apply the heat gun to shrink the stuff on the ESC.. Could that hurt the corrosionx? I'm thinking the heat won't be a big deal, the package talks about it being used as a lube in high heat environments. And of course the ESC is going to get hot while in use. But it's better to ask questions first and be prepared right? Thanks. Included are pics of my two float planes. -Jay |
Here... With USPS shipping it was just under $23. Seems pricey but if it saves my electronics I suppose it is worth it.
I went ahead and pulled the heat shrink off the 80a ESC and one of my RXs. They're soaking in the jar now. Tomorrow I'll probably put the plane back together. -Jay |
The stuff is pretty neat. I wasn't quite sure what to expect. It's like a dark green medium/light oil. Doesn't seem to be too nasty to handle. Using this dunking technique this 16oz jar should last me forever hehe.
Tomorrow I'll pull the stuff out and let it drip dry. Then re-cover the ESC and put the RX back in it's case. Then I'll have to put the Toledo back together and take the Taylorcraft apart to treat it's stuff. -Jay |
I have only used the spray CorrosionX, but it seems to be a grease/solvent mix. Once the solvent evaporates the grease is left behind. It may liquefy when you shrink the plastic around the ESC, but I don't think it will be as hot for as long as a reasonably enthusiastic flight. And if ESCs need all this cooling, why do they wrap them in a plastic sleeve anyway? But I digress.
Wiping off? Get some on your hand and see if it wipes off. Better yet-get some on your monokote and try to get trim to stick to that area. Accidentally WIping CorrosionX off is very low on my list of fears |
A few of my flying buddies and I use Corrosion X and that at the time we were using it, it was stated that only use on the recievers. I would just dip the reciever in some corrosion X and let it drip dry overnight. I don't even bother to wipe it off.
It was posted here I think some time ago not to use Corrosion X on servos and ESC and of course the motors. I have not had a bit of trouble by just using it on just the receivers. That's my 2 cents worth. Have Fun! Roland |
I'd use Cx on the circuit boards inside the servos, but not in the potentiometer. And almost all servos have brushed motors, so I don't think you want it on the commutator.
Be sure to hit All your connectors. Brushless motors: There's nothing to hurt unless the dried CorrosionX adds a lot of viscosity to the bearings. Receiver and Speed controller? Dunk 'em. |
What Jim C said! If you want to treat the servos, apply the CorrosionX to the PC board with a brush. Absolutely treat the ESCs - Dunk 'em.
Be sure and treat ALL the connectors. Without treatment, water will wick up between the insulation and the small strands of the conductors and start to corrode the individual wire strands. McD |
Latest blog entry: LEDs on my T-28
Hey, Great information guys. I am fixing to put my first water plane together and have really wondered how to use this CX stuff. This thread has helped answer a few of my concerns.
If I read this right...dunking the brushless motor is a good idea? Do you just oil the bearings afterwards? Thanks, Ken |
The motor is the least of your worries.
Corrosion X will protect the laminations and the coils of wire. Those are stationary. Any excess on the magnet can will probably be slung out. Be sure to coat the shaft and bearings, where rust actually can degrade performance. |
Thread Tools | |
Similar Threads | |||||
Discussion | How many amps can this battery handle? | captaintomo | Batteries and Chargers | 6 | Oct 09, 2010 07:54 AM |
How easily can Depron be had in Belgium Europe? | Bschulz | Scratchbuilt Indoor and Micro Models | 5 | May 03, 2005 06:40 PM | |
Determining how much heat a motor can handle | austinflyer | Power Systems | 1 | Mar 07, 2004 05:52 PM | |
how much can it handle? | ang 123 | Beginner Training Area (Aircraft-Electric) | 4 | Feb 14, 2002 08:06 PM | |
Rocket 400...how much abuse can they handle? | Woody | Electric Plane Talk | 2 | Jun 27, 2001 07:04 PM |
