Aug 04, 2009, 08:41 PM
making my own planes...
decones's Avatar
Originally Posted by skyzking
Hi Andre, it looks like you have cut the carbon as one piece for the wing? How did that work out on the leading edges?
Abdullah...
I did a carbon overlap just in one side of the wing, even in the leading edge, the vacum and mylar will do the rest. All the leading edge may need some sandpaper and repairs after the vacum bag, I just use sandpaper and vinil oracover to ajust it.
Old Aug 17, 2009, 07:36 PM
sunfowerggs
A moderator felt this post violated the following rule: Excessive Advertising (Spam).
Aug 19, 2009, 01:12 PM
jattamasso's Avatar
Olá André
Bom trabalho, gostava de ter a tua persistência.
Quanto tempo demoras a fazer uma asa?
Aug 21, 2009, 08:32 AM
decones's Avatar
Originally Posted by jattamasso
Olá André
Jatamasso,
- 2hrs cortando ela na CNC
- 5hrs otimizando ela para laminar (corte na ponta sa asa, lixa, longarinas, tubos para passar fios dos servos,..etc)
- 1 dia para laminação (trabalhoso, depois de cortar os tecidos e arruamr tudo ainda tme que por dentro do vacum bag, trabalheira)
- 3hrs lixando o excesso de resina e colando vinil para acabamento
mais ou menos isso
Aug 21, 2009, 08:37 AM
decones's Avatar
Originally Posted by M. Koch
Hi André!
Sorry for answering so late, but was very busy the last time!
The stab dimensions are;
span: 380 mm, width: 100 mm!
I hope this helps you!
Ciao, Marcus
Hi Marcus,
I'm considering to buy a Raketenwurm 2b from USA.
I will use this plane as my plug, the idea is to buid the molds and start building Raketenwurm planes such as you do, nice work :-)
So, the question is, How big is the inside of Raketenwurm fuse's?
Will fit my Polyquest 5S lipo pack Dimension(mm) : 32.5 * 50.5 * 151.5 ???
Regards,
André
