Aug 17, 2011, 09:07 AM
CrashingDutchman's Avatar
With this one, you can connect multiple to show voltage of multiple batteries. Maybe it is easy to have the description here:
Super Simple Mini OSD
Easy to install and configure the Super Simple Mini OSD connects directly between your cameras video out and the transmitters video in. 2 Super Simple Mini OSD units can be used together to display voltage for up to 4 individual 2~3 Cell Lipoly batteries.
Features:
Voltmeter & Stopwatch
Double Voltage Input (Up to 4 voltage inputs, requires 2 x Mini OSD units)
Programmable Display Content
Supports NTSC & PAL
Specifications:
Weight: 4g
Dimensions: 51 x 18 x 8mm
Working Voltage: 7.2~12v
Aug 17, 2011, 12:21 PM
Originally Posted by foufly
Hardly worth it without a home arrow? Maybe the next generation will have one?
Could be! I noticed in the comments section that the people who actually make the units are planning on this to be included in the next one out.
From the comments section...
Hrncek(9)
I wrote to the producers AEORC and they said they are planning to put home arrow this or next year. You will have to buy new hardware, firmware update will be not possible.
Sep 07, 2011, 10:43 PM
aka Helidaho
AeroVideoUS's Avatar
Can this be used to display the RSSI voltage of the control Rx? I think my Chainlink UHF RSSI voltage is in the 2.0 - .9 range, is that too low for this OSD?
Nov 02, 2011, 02:23 PM
Tailwind1's Avatar
HK simple OSD
Does anyone know if this will work with FM receiver such as Futaba?
Jan 05, 2012, 11:15 AM
DuskWolf's Avatar
I have a different question. My camera and VTX are on 3.3 V, so what is the signal voltage range of the OSD? Will it be suitable for the VTX ?
Jan 08, 2012, 03:54 PM
Hi,
I have a problem with this osd. The text appears as a shadow in the image and become unreadable on a bright image. Is there a system to boost the signal?
Jan 08, 2012, 04:08 PM
GoldCraft's Avatar
Yep....Check here...
http://fpvlab.com/forums/showthread....-%284s-RSSI%29
Jan 08, 2012, 06:27 PM
aka Helidaho
Originally Posted by GoldCraft
Cool, thanks! I ended up getting one and have been playing around with it.
Paul
Jan 11, 2012, 01:58 AM
fly by night
BCSaltchucker's Avatar
got mine up and running. Displays voltage from my 2S flight batt and my 1S video batt correctly. But the display is located across the screen 1/3 down. This is a poor location for flying. When I press the button nothing happens. Is there a trick to getting the display options to work with the button?
Jan 11, 2012, 03:21 PM
fly by night
no ideas? I guess I got a unit with a non working button
Jan 12, 2012, 05:10 PM
Originally Posted by ponyofs
Hi,
Nobody ?
Discussion Simple OSD XL RSSI wiring. ziomatrixacs FPV Talk 6 Dec 25, 2010 09:25 PM
Sold NIP HK Super Simple HK30A ESC $15 shipped jmrust Aircraft - Electric - Power Systems (FS/W) 3 Dec 09, 2010 06:58 AM
Sold NIP HK Super Simple 25-30 amp ESC $15 for one or $25 for 2 shipped jmrust Aircraft - Electric - Power Systems (FS/W) 4 Dec 07, 2010 04:58 PM
Wanted GPS for Simple Osd XL mrfliboy FPV Equipment (FS/W) 0 Nov 11, 2010 02:30 PM
Discussion HK - OSD Pro ... YES!!!!!!!!!!!!!!!!!!!!!!!!! Cralis FPV Talk 28 Sep 19, 2009 12:04 PM
