May 15, 2011, 09:07 PM
kensp's Avatar
I have now glued a one meter long carbon fiber tube into the bottom of the wing using epoxy. This tube was placed next to the front wooden spar & was 3mm in diameter. I used a Dremel style tool to cut the grouve using a 3mm router bit. By cutting the grouve next to the front spar I made making a straight cut easier.
I have placed a bead of silicon sealant arond the elevator servo to prevent water getting into the fuselage through there.
My new batteries have arrived so now its only a matter of letting the epoxy cure, charging the batteries and then test flying.
Ken
May 16, 2011, 03:50 AM
Space User
chir72's Avatar
Originally Posted by baddb1
Nice flight!! Is that a camera mount you added on top?
Yes it is a go pro camera mount
May 16, 2011, 12:47 PM
Spray rails
Simple spray rails, made from the plastic of a blister-pack.
Glued on with white Gorilla glue, painted with red acrylic paint.
Such a thing could not be molded into the model, you have to do it,
if you want to keep the spray out of your props.
May 16, 2011, 01:31 PM
TripleW's Avatar
That looks like an easy mod with some clear .020 plastic. I'd probably put a swollow cut with an xacto and ca them in. Thats what I did with the ventral fin on the WildCatFish. TW
May 16, 2011, 09:57 PM
kensp's Avatar
My test flight yesterday was abandoned because of an intermitant aileron servo. On investigation this was traced to a faulty "Y" lead. Thr "Y" lead has been rebuilt and a further attemt at a maiden flight will be made this afternoon when the wind drops.
Without ailerons all a I could do was to make some water handeling tests using diferential throttle. These tests were successfull but I may add a bit more diferential to get a tighter turn at slow speed while on the water.
Ken
May 17, 2011, 03:05 AM
kensp's Avatar
Well the maiden flight has been carried out and a few problems have become apparent.
Firstly the high thrust line is forcing the nose down at full throttle making the CL-415 dig its nose in while on the water. I had to abort my first Take Off attempt because of this. On the next attempt I used 3/4 throttle untill the model was clear of the water and then went to full throttl for the climb out
Secondly a large amount of up trim was needed even though my GC was at the recommended 70mm. I suspect that the recomended CG may be too far forward. This would exasibate the nose down tendency at fuul throttle when the model is on the water.
Thirdly the ailerons were not very effective at slow flight and I had to add some rudder to make the model turn onto its landing approach.
The one thing that stood out is that this model certainly has a presence when flying.
I have just measured up the CL-415 and used my CG formula to calculate where the CG should be.The answer was 5.9 inches from the TE. Aproximately 3/4 of an inch behind the recomended point.
Ken
May 17, 2011, 05:05 AM
Rudi's Avatar
Hi guys,
my pimped CL-415 is still waiting for a better maiden weather. Any suggestion about rec. CG and aileron and rudder movements ?
Used two Turnigy L2205-1350 motors with 2x 20 A controllers with GWS 8x4
counterrotating props. with diff. thrust mix.
Rudi
May 17, 2011, 05:59 AM
I'd rather be flying
baddb1's Avatar
Ken
Thanks for verifying the CG point. I noticed the same nose heavy condition when using the factory CG recommendation. I just moved the battery until I got it where she flew perfect! Not very scientific, I know . How does one calculate the correct CG anyway? Thanks.
May 17, 2011, 06:09 AM
baddb1's Avatar
Originally Posted by Rudi
Hi guys,
Rudi
Looks good! I like your little details that were added! As mentioned above, I would move the CG back.
May 17, 2011, 08:33 AM
6 months to finish a rtf
pulsery2k1's Avatar
baddb1
you can use this for cg:
http://adamone.rchomepage.com/cg_calc.htm
but the nose down tendency is in part because the
prop's are above the center line. my other high wing
sea plane has the same problem, I just feed the throttle in
slowly till the elevator becomes effictive enough to overcome
the high center line
May 17, 2011, 09:19 AM
This is a very good CG calculator. It takes into account many things the other ones do not, such as the effect of the fuselage, tail position in the wing wake, CG height, etc. It will give much better results, particularly with airplanes that are unusual in any way, such as having a large fuselage, or a big vertical distnace between the wing and CG. I think the CL-415 falls into both of those categories.
https://www.rcgroups.com/forums/show....php?t=1106300
It is also useful to place the components virtually, to get the CG to come out at your desired static margin, before you even assemble the airplane. I really like this calculator.
Kevin
May 17, 2011, 12:47 PM
baddb1's Avatar
Interesting calculators, thanks! Now with my motor calc program and these I could be asking for trouble!!
May 17, 2011, 01:51 PM
Dixie Normious
Eastcoast78's Avatar
Here's one Ive used.
http://www.nasascale.org/howtos/cg-calculator.htm
May 17, 2011, 02:02 PM
KC9TPL- Get Legit
BloomingtonFPV's Avatar
wing support
I have to make my wings so they split in half for transport. I would like to do away with the support rods that connect to the bottom of the fuselage. What else have people done to strengthen the wings without gluing them permanently?
May 17, 2011, 11:38 PM
Rudi's Avatar
Many thx, it is so easy to making the CL-415 looks like a real airplane and not like a cheap china toy. Any movement recommantion ?
Thx
Rudi
Sold MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 0 May 09, 2009 07:05 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 06:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 04:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 12:36 PM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 09:54 PM
