Mar 18, 2011, 04:52 PM
Arduino Nav Light Controller
I had an Arduino Mini Pro laying around and I needed some navigational lights.
I wrote and debugged the attached in a few hours.
Its easy to change.
The Arduino maybe a little pricy at $24. But it is flexible.
Put a resistor inline with whatever type of LED you're using and connect it directly to the pins.
YMMV
Enjoy
Mar 20, 2011, 01:58 PM
Dave the Rave
dmccormick001's Avatar
What kind of file is that? .pde?
Mar 20, 2011, 05:39 PM
400' + is where fun starts.
Martin Y's Avatar
it opens with Arduino software.
Mar 20, 2011, 07:21 PM
i think if you rename *.pde to *.c you can use Winavr or AVRStudio but you'll need to add 'make' file for winavr.
Still i could have missed read another thread
Mar 20, 2011, 07:45 PM
Martin Y's Avatar
Here you can open with notepad.
Mar 20, 2011, 11:25 PM
Thanks Chuck
Mar 21, 2011, 01:40 AM
Sorry, I thought Arduino's were more popular.
Here is the one I used, but there are several sizes.
http://www.arduino.cc/en/Main/ArduinoBoardProMini
Here is the GUI to program it. Though you can use text editors, etc, as outlined above.
http://arduino.cc/en/Main/Software
May 13, 2011, 01:36 PM
Night Flyer
phil007's Avatar
Chuck,
Do have a video of your aircraft running your Arduino programming? Thanks for sharing you code.
Phil
May 16, 2011, 01:39 PM
No, sorry. Not right now. Next time I have one running I'll post it, but it may be a few weeks.
But the code is pretty self explanatory.
Some stead light pins.
two flashing pins which flash at slightly different rates so they are not synced like a real aircraft.
And a LED revolving light simulator, which ramps up the brightness from zero to 70%, jumps to 100%, jumps back to 70% then ramps back down to 0. Looks like a revolving
light.
Chuck
May 18, 2011, 02:26 PM
Rendy's Avatar
video
http://www.youtube.com/watch?v=vIdhsNJ-lfg
May 19, 2011, 01:44 AM
Wow, thats running much faster than on the Arduino I used.
I guess there is different timing per Arduino.
Looks twice as fast.
You can adjust it if you look at the code.
May 19, 2011, 11:32 AM
Rendy's Avatar
I ran your code on Arduino Uno (16Mhz). The input signal is the PWM of channel 1 servo.
May 20, 2011, 09:17 AM
Closed Account
I love my BoArduino. Basically the same thing, just for a breadboard. I've been toying with the idea of using it for a light controller. Code looks great!
Jun 01, 2011, 10:25 PM
If i need to drive 1-watt LED, i can't just add resistor to this 50mA pins directly.
Does anyone know of a driver circuit to drive a constant current to a 1-Watt LED (say 300~350mA)?
Or
Is it necessary to have constant current driving the LED as the driving from the pin is PWM? Just use FET to turn the LED ON-OFF? Got circuit i can use?
Jun 02, 2011, 01:53 AM
For the big leds, I use a transistor circuit.
Drive the transistor's base with the Arduino pin (nneeds a resistor).
Switch the current for the LED with the collector/emitter. This also still needs the proper resistor for the LED current.
The good thing about this, is it still works with the rotating light simulator.
Discussion Brushless Motor+ Speed Controller+ Arduino Uno= Problems d4n1s Power Systems 3 Nov 26, 2010 02:03 PM
Discussion arduino and 3in1 controller unit from lamav3 heli sk8tom Coaxial Helicopters 0 Nov 01, 2010 06:28 PM
Sold SOLD Light G3 W/controller and Add on. -S- Aircraft - General - Miscellaneous (FS/W) 2 Sep 12, 2010 09:46 AM
Discussion iPad-controlled blimp - Arduino controller flitelab Multirotor Drone Talk 0 May 19, 2010 11:52 AM
scale nav light placement cathode Scale Kit/Scratch Built 2 Nov 22, 2002 12:54 PM
