May 26, 2013, 03:28 PM
Originally Posted by bakchos
check the PPM signal wire, what transmitter are you using ?
if you unselect the PPM mode from your transmitter this can be a cause
I'm using dx 7, took the signal straight from the module ppm
May 26, 2013, 03:50 PM
let me know how to contact the manufacturer, thanks.
May 27, 2013, 12:14 AM
Chriscool's Avatar
twhat is the e-mail di Sid?
Check Sid's store...
http://www.rangepiloting.com/index.p...age=contact_us
Jul 01, 2013, 04:23 PM
tupelo's Avatar
Chainlink and FrSky TFRSP as a relay
Hi
Has anyone tried to use a PPM outputting 2.4GHz receiver as a relay system with Chainlink?
I am tired of removing the 2.4GHz module every time I fly Chainlink. TFRSP outputs PPM for channels 1-9 as described here:
http://www.frsky-rc.com/ShowProducts.asp?id=80
So maybe I could use that output with the PPM input of Chainlink?
New Product Long Range UHF RC system now avail on STOCK thomasscherrer FPV Equipment 14517 Oct 05, 2023 01:13 AM
Discussion Long range flight, UHF TX antenna optimisation Ian Davidson FPV Talk 9 Nov 09, 2010 03:23 AM
Discussion Long range UHF compatibility question wingsuitdude FPV Talk 5 Sep 20, 2010 05:31 PM
Discussion Has anyone tried the new Long Range UHF system? djdaveq FPV Talk 4 Dec 06, 2008 01:38 AM
