This thread is privately moderated by Bombay, who may elect to delete unwanted replies.
Mar 14, 2011, 11:23 AM
Slow Flyer
Bombay's Avatar
Build Log
Hobbyking Guanli Icon A5
Against my better judgement, I started the build for this infamous plane.
https://www.hobbyking.com/hobbyking/s...dProduct=13848
I bought it in the ARF form from an old-timer at my field. This was at least 6 months ago. There was a float fly-in coming up, and it looked like a breeze to put together. He didn't tell me otherwise. Long story short, I soon found out by reading this thread that there were numerous issues. I shelved it...and ordered a few parts that I thought I would need.
It is raining here again (finally) in my part of the country, so I decided to take the down-time and go for it. I soon became discouraged again after re-visiting the Guanli Icon thread here on rcg. Nonetheless, I moved forward...
Potential Mods
Reconfigure battery tray
Seal decals and foam surfaces with Minwax Poly
Lighting
No wing floats
Waterproof gasket on cockpit/battery access
Deepen step
May move elevator servo from battery tray to direct install on horizontal stabilizer
Battery tray
The servo and battery tray is a joke in this plane. While it is a nice balsa tray, the battery slot wouldn't fit a 2200mah...or even a 1500mah...not even the 1300mah I use frequently. The slot is very, very narrow. I popped the battery tray portion out and put in a balsa-foam combo that would fit a 2200mah and larger...and would allow ample room to slide the battery forward or backward as needed. Not too difficult with the right tools (screw driver for prying, dremmel for cutting and sanding, 6mm depron, foam-safe contact cement, and some epoxy). Done!
to be continued...
Parts being used
https://www.hobbyking.com/hobbyking/s...idproduct=2046
https://www.hobbyking.com/hobbyking/s...idproduct=9745
https://www.hobbyking.com/hobbyking/s...?idProduct=662
http://rctimer.com/index.php?gOo=goo...5&productname=
Question Is there a simulator that supports Transmitter provided w/ Mini Super Cub wingnutsdad Simulators 3 Sep 10, 2013 07:02 AM
Discussion May God bless Japan and all people on Japan twn Chen Japan 1 Mar 26, 2011 06:08 PM
Link Gaui 330x Resource red_z06 Multirotor Drone Talk 1 Sep 19, 2010 03:37 PM
Need some scale modeling resource help ORANATOR Scale Kit/Scratch Built 4 Jun 25, 2003 08:47 AM
