Aug 03, 2011, 06:14 PM
sideburn's Avatar
Originally Posted by Stugoose
Ebay, reliable seller
IDK sorry mods if ebay link not allowed but only place i have found
http://cgi.ebay.com/Blade-BLH3502-Ta...item43a8be5c23
I buy from them all the time
oh yeah those guys.. ive bought from them before too
Aug 03, 2011, 06:31 PM
Stugoose's Avatar
Originally Posted by indoorheli
Wowhobbies had them instock last I checked
Did you fix the fried tail FET? You can fix them for about a buck and a half
I sold that heli not worth the hassle, My second one has a bad gyro so im gonna have to restore it to stock because i broke a few booms and a body mount in the troubleshooting, So now i got to restore it and send it in, It was relatively new when this occurred, My third one works great put the fast flight blades cause my high performance blades with damaged and a .3 or something inch extended hollow carbon tail boom with wires going through them
The guy that fets my mini z's could do it for me for little money but he doesnt do helis so i gues ill forget about it
Aug 03, 2011, 06:59 PM
Can't get enough
jabsten's Avatar
Aftermarket skids
http://www.microheli.com/store/produ...roducts_id/393
Has anyone tried these?
J
Aug 03, 2011, 07:08 PM
Originally Posted by jabsten
Seems kind of steep to me. Stock landing gear is only $5. I've beat the piss out of mine, and only broke one... You'd have to break it 5 times to make that start paying off...
As to performance increase... I'm a skeptic.
Aug 03, 2011, 08:35 PM
Heli collector
livonia bob's Avatar
Originally Posted by stevebarrow
Dumb question but have you checked the 0 pitch position on these low powerless helis? Mine was flying like it needed a new motor until I happened to hit throttle hold and noticed that mid stick was showing negative pitch, after fixing that the power was back
This is a great heli, fun to fly and very tough.
Yes made sure all were set up the same, and differently even have flown them all as separate models and as the same model on one TX and on three different TX's. Have tried different pitch settings. Of the three the first one has always flown the best, next would be #2 and then #3.. Even tried a new motor in #3. #2 had a problem with losing control when 15 feet away. I seem to have fixed this by re soldering the antenna wire and power leads to the board.. #3 just had a new servo installed as one went bad..and a new board..
Using the Scotch tape mod on the booms has really cut down on the breakage on all three..
Aug 03, 2011, 08:46 PM
Get out and fly it!
stevebarrow's Avatar
I missed the scotch tape mod is this just wrapping it around the boom?
Aug 03, 2011, 08:55 PM
Heli collector
Yes I now just do two wraps around the boom right where it meets the frame and then a little hot glue at the joint.. Use the clear tape..
Aug 03, 2011, 09:27 PM
RC Reviews & Tx Setup Guides
Tom Z's Avatar
Bob's scotch tape mod (pat. pending) works great.
I used it on my mCPX boom. The boom held up much better in a crash.
In fact it didn't break anymore where the tape was but it did break in the frame as I couldn't tape the part that goes into the frame or it wouldn't fit.
So I went to a solid boom. The problem is it is hard on the frame
and can break it where the boom goes into.
Tom
Aug 04, 2011, 12:03 AM
Heli collector
Tom
That's why you are to put the hot glue at the joint..
Aug 04, 2011, 12:27 AM
Gone Insane .... Back Soon!!
Meebo's Avatar
Aug 04, 2011, 12:43 AM
HELP I AM BEING SET UP!!
maukabud's Avatar
He can't...still working on the patent.
(I just used a thin coating of 5min epoxy on mine- holds good enough, but can be gotten out if needed.)
Aug 04, 2011, 01:01 AM
Tom Z's Avatar
When Bob wasn't looking I snapped some pictures of his heli.
You can see the "hot glue" on the tail boom going into the frame mount.
This will apply to the mCPX boom/frame too.
There is JB Weld also to reinforce the parts.
Next is to snap some pictures of the boom with the scotch tape mod...
Tom
Aug 04, 2011, 01:13 AM
maukabud's Avatar
hey wait that ain't no MCPx....and on a 4Site box no less.
Yer busted.
Aug 04, 2011, 07:19 AM
Heli collector
Tom
You must of taken those pictures before I used the black Sharpe to make all the glue black to match the frame..
Aug 04, 2011, 08:57 AM
Tom Z's Avatar
OK, I'm busted!
Those pictures were posted for me in my review thread when I asked Bob
if he could take some pictures for me of the "hot glue & JB weld reinforcements".
So same idea for any helicopter for the boom frame mount.
Here is a picture of the JB Weld after a black sharpe. It blends in with the frame.
Tom
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15723 Feb 04, 2024 12:53 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 03:28 PM
