RF Explorer Spectrum Analyzer - Now 6GHz supported! - Page 150 - RC Groups
May 09, 2018, 06:16 AM
Originally Posted by AsmCoder8088
I've made some updates to the UnityRFE visualizer:
https://youtu.be/TTpfyjHpDyo
- Column select for markers
- Record and playback data
- 20% faster rendering
Available here:
https://drive.google.com/open?id=19Y...qgneJFNBGTjQr_
Really great job - thansk for sharing !
May 10, 2018, 02:36 PM
hwalker and macfly, thanks for the responses.
I have fixed a bug concerning the recording functionality, where if you record to a non-empty slot it actually opens the file for appending rather than creating new file from beginning. If any other bugs are spotted let me know, but that is the only one I know of so far. I will be releasing an update soon.
arocholl, is it possible to have the RF Explorer stay in DSP mode="fast" during power cycles?
Every time I power on the device it goes back to DSP mode="auto" (which is the same as "filter" for the band I monitor). If it is on filter then I don't see the radar emissions that I want to see.
May 10, 2018, 04:02 PM
Electric powered
arocholl's Avatar
The device always restart in DSP:Auto by design, to prevent novice users from measuring with a wrong setup.
But you can easily set it programmatically the way you want from the application: use SetDSP command (Cp) see www.rf-explorer.com/API documentation for more details.
May 15, 2018, 02:20 PM
Thanks arocholl.
I have now published the source for the UnityRFE visualizer, it is available here:
https://github.com/daniel-SG1/UnityRFE_src
And for those who are not able to compile the source, I have the latest binary available here:
https://drive.google.com/open?id=1hE...UioMa7T3ODzsF7
The latest version also fixes the bug when recording to a previously used slot. So far as I know at this point, there are no other bugs. If you find one, let me know.
And for those who are curious about how the rendering works, I have a brief explanation. Each data point is represented by a cube that is scaled vertically according to the amplitude of the data point. There are 112 data points (cubes) per row, and 125 rows make up the waterfall. Whenever it is time to step forward, the back row gets moved to the front, and its contents are set equal to that of the incoming data. At this point, having simply moved the back row to the front, this would give the impression that the waterfall is moving away. So the classical approach would then be to shift all rows forward by one to keep the waterfall in place. However, this results in updating the position of all of the cubes, of which there are 14,000, which significantly reduces the frame rate. So, I then parented every cube to a row object, and each row object to a single waterfall object, thinking I could then just update the position of the waterfall object and it would not be so slow... However, it seems that under the hood, Unity is still updating each cube position, so no luck. Then I decided instead to simply allow the waterfall to move, and then move the camera object to follow it. This approach worked, and the frame rate is quite fast as there is minimal updating of positions.
May 16, 2018, 10:37 AM
Electric powered
arocholl's Avatar
Thank you for the added details. There is a very interesting and ingenious solution in your approach.
May 23, 2018, 09:21 AM
Electric powered
arocholl's Avatar
New Firmware v1.26 / v3.06 and Software v1.26.1805 available
We are happy to release final version of firmware v1.26 and software enabling Presets in RF Explorer Combo spectrum analyzer models, as well as new the powerful Preset Manager tool for Windows and Linux to enable easy creation and edition of multiple presets from your Computer.
In addition to this, the new firmware for RF Explorer WSUB1G PLUS v3.06 adds support for <standard> expansion modules RFEMWSUB3G and RFEM24G so you are now able to expand your device with additional frequency range. We are working hard to bring you additional <Plus> expansion modules soon.
For detailed info and download please visit this link.
Our special thanks go to the Beta Testers who contributed with feedback and support testing Presets deeply.
Today, 10:22 AM
Is the final release 1.26 the same file as was sent out to beta testers a couple of weeks ago or do I need to upgrade to this release?
Today, 11:35 AM
Electric powered
arocholl's Avatar
It has a minor change, we suggest upgrade from RC used in the beta testing. You will see 1.26 "8 may" in the about for the new version.
Discussion Introducing the FY20A on 3D EDF JET FYETECH Electric Ducted Fan Jet Talk 5 Jan 29, 2011 11:26 AM
For Sale rf g5 program dvd only... ed1978 Aircraft - General - Miscellaneous (FS/W) 6 Feb 28, 2010 06:01 AM
Idea CC Beta Program RC Man Castle Creations 9 Oct 07, 2005 01:27 PM
Castle Creations BETA Program Kate O'Neil Castle Creations 0 Aug 23, 2005 06:41 PM
What is 1.10 and an Explanation of CC Beta Testing Program Bernie Wolfard Castle Creations 3 Dec 12, 2004 05:56 PM
