May 05, 2011, 04:43 AM
F3B Clinic
Can you guide us the proper way on how to align the winch so that the line can run and rewind tidy on the drum? That is the line will not spool to one side of the drum.
Thanks.
J
May 05, 2011, 10:00 AM
David,
Even when you have been flying F3B for over 35 years as we have, there are always new tricks to pick up from seeing other peoples methods and you never stop learning with this sport. Setting off to Holland now for the F3B Euro event to try a few!
Keep up the good work...
Steve
May 05, 2011, 10:06 AM
F3B and F3K
RetoF3X's Avatar
winch alignment
Hi polar bear
This is how I learned it and it works fine:
When you have set up the winch, spool up line so that it is under quite some tension. Now lift the winch line up as high as you can and let it go. This will help to get the winch line lying straight on the ground and free it from obstacles (if still present, walk the line and free it).
No begin spooling up line, say at the left side of the empty drum. I deliberately move the right side a bit forward, so that it winds up unevenly (it spirals to the right).Open the brake and release the line from the drum again.
Move right side of the winch a bit back, watch the spirals. The pitch of the spiral should be smaller now.
Work the right side of the winch incrementally backwards until the spirals just disappear and you are all set.
Reto
Latest blog entry: thoughts on contest flying
May 05, 2011, 10:26 AM
Detail Freak
target's Avatar
I've noticed that sometimes when the mono will spool on the drum straight under the load of the plane, it doesn't when you are just winding down the chute...
So, if Reto's technique above gets you to what I just described, then just adjust the winch a little afterwards to get it spooling on roughly even when the tension is off as well as on the line.
I always only move one side of the winch or frame, as Reto mentioned; leave the other side alone/staked.
Good luck,
Target
May 05, 2011, 03:57 PM
or GPS, F, J, K, or even TD
FLY F3B's Avatar
wind greatly affects the unloaded line spooling. Gotta watch out for that.
M
May 06, 2011, 01:21 AM
MCS / NCSS / SVSS / LSC / SAM
David Olson's Avatar
F3B Clinic Videos
Mike's 2nd Speed Run / Target's Launch - Estrella:
Mike's 2nd Speed Run - Tanga (2 min 55 sec)
Tim's First Speed Run - Ever:
Tim's First Speed Run (1 min 6 sec)
Tim's Next Speed Run:
Tim's Next Speed Run (1 min 7 sec)
This is worth real money - just pure gold. Listen carefully to what Kyle is telling Aaron.
Kyle's Speed Run Tips for Aaron:
Kyle's Speed Run Tips to Aaron (1 min 29 sec)
Aaron's First Speed Run: (gusting to 27mph)
Aaron's First Speed Run (1 min 18 sec)
May 07, 2011, 12:23 AM
F3B Clinic Videos
The Video Post Production Department is closed for the weekend.
The footage will start flowing again next Monday. I need a break.
May 07, 2011, 04:18 PM
AMA 5285 LSF 8104
Aquila Guy's Avatar
David -
Thanks for doing this!
Scott
May 10, 2011, 01:25 AM
F3B Clinic Videos
Kyle's Distance Instruction:
Kyle's Distance Instruction (5 min 1 sec)
May 11, 2011, 01:09 AM
F3B Clinic Videos
Kyle's Distance Instructional Flight:
Kyle's Distance Demo Flight (5 min 52 sec)
May 11, 2011, 01:35 AM
F3B Clinic Videos
I posted videos of each pilot's flying at the F3B Clinic on my FTP site if you want to view your own flying. There were too many of them to post here on RCG. You can download any video if you care to. I will leave them up for a couple weeks and then take them down. I was not able to film everyone since I was working on Base B for a while or timing etc., sorry Sean.
http://gallery.me.com/davidj.olson
One more time, this is how it's suppose to be done:
IMG 1006 (0 min 56 sec)
Tha, tha, tha, THAT'S ALL FOLKS!!!.................................
May 11, 2011, 06:28 PM
Videos
Dave:
Fantastic job on all the vids. Can't thank you enough.
Your time, dedication and enthusiasm towards this sport is great to see.
From all of us out there, please keep up the good work!
Steve
May 11, 2011, 09:00 PM
David Cortina's Avatar
Thanks a lot Dave, it has been fn and educational to view.
David C
May 11, 2011, 09:03 PM
Sean Worthington
S-1-11B's Avatar
Thanks for posting these Dave. What a fun day!
Sean
May 16, 2011, 07:38 AM
Question about Distance task:
Is there any fixed flying pattern , say pattern 8, or similar to MoM that all planes turn away from the "slope"?
If the plane cuts a turn, should he turn back to that base immedately (like F3F) or he cannot(like MoM)
PB
Discussion US F3B team clinic Avaldes Sailplane Talk 0 Jan 10, 2007 10:00 PM
