Mar 03, 2011, 02:48 PM
Turnigy 9x jack input?
Hi, you can use jack for Turnigy X9 with another firmware as well as input.
Thanks for the reply
Mar 03, 2011, 04:39 PM
65 years of RC flying
Daedalus66's Avatar
Do you mean can you use the trainer jack to upgrade the firmware? No. You need a programmer hooked into the circuit board.
See this thread:
https://www.rcgroups.com/forums/show....php?t=1266162
Mar 03, 2011, 05:37 PM
lipoflyer's Avatar
the jack can be used on a flight sim or in trainer mode
Mar 03, 2011, 06:06 PM
i don't know if it can use this connector as an input (if supported by hardware) when I put the other firmware
Mar 03, 2011, 06:48 PM
Daedalus66's Avatar
Are you asking if the transmitter can function as master (i.e., getting input from the slave transmitter) in a trainer setup? Which firmware?
Mar 04, 2011, 03:30 AM
Yes so I could lend the proceedings a friend
I have the er9, and he original
Mar 04, 2011, 04:27 AM
Probbably yes, but I dont know whether it is usable. And there were troubles with signal denying by inserted but turned off RF module (see added resistor mod).
- if TX power switch is in OFF position, it is turned on by inserting jack, and in this case it generate PPM output and do not start transmitting. (student mode, or simulator)
- if TX power switch is ON, it does not output PPM there, and jack is in input mode - a teacher. How it works and whether it does anything (with original firmware), is not known to me, at all. Also the way of give/take control to/from student, is unknown to me (perhaps just plug in/unplug of jack?)...
I guess that the best You can do is to upgrade firmware and create set of conditional mixes that would let You use switch to give/take control for buddy..
Discussion Turnigy 9X receiver setup agent1940 Radios 8 Jul 29, 2016 03:20 PM
Contest Turnigy 9X 9Ch Transmitter vs Spektrum DX6i alexbazzi Radios 45 Jul 23, 2011 08:51 PM
Help! Turnigy 9x Radio Reset Problem cintiq Radios 0 Sep 08, 2010 03:00 AM
Question How to program the Turnigy 9X settings for a specific model? djacob7 Radios 1 Sep 05, 2010 07:26 AM
