This thread is privately moderated by Tom Hunt, who may elect to delete unwanted replies.
Feb 20, 2011, 09:30 AM
Head NEAT geek
Tom Hunt's Avatar
cowl vents
did not like the idea of no air exiting the cowl. I cannot believe that even in the stock set-up with a battery clogging up most of the channel in the fuselage that much air is going over the motor and thru the fuselage. So..... I took out the dremel and knife and carved some "scale" cooling slots in the semi-openned molded cowl flaps.
I also openned up some more of the dummy engine (between the rocker arms)
Help! SkyBench Oly3 electric cooling vents Gliderbill46 Sailplane Talk 2 Oct 30, 2010 04:05 PM
Discussion Cowl Cooling Vents - In-out Size josefvs Fuel Plane Talk 4 Jul 04, 2006 07:58 PM
Do you run cooling vents? dhauch Electric Sailplanes 5 Dec 09, 2003 04:30 PM
Switchback Fuselage Vents butter_fingers Parkflyers 8 Jun 19, 2002 11:29 AM
Cooling air vents in a Simple 400?? ErnieR High Performance 9 Apr 20, 2001 06:41 PM
