Build IBCrazy's Cloverleaf - The ultimate circularly polarized aerial antenna! - Page 51 - RC Groups
Jun 06, 2011, 10:04 AM
techspy's Avatar
Thanks, I will give it a try, if I can find room to put the tx ant underneath. Here is a pict of the tx antenna btw.
Jun 06, 2011, 10:14 AM
aka Nigel Uno
10km / 6.2 miles with crystal clean video @ 1.2GHz 800mW
Description:
Cloverleaf on the plane and 5 turns helical on rx (the helical was tuned on a different channel)
Shooting for 15km next time with same config
Ciao
Luca
Jun 06, 2011, 12:30 PM
Engineer for Christ
IBCrazy's Avatar
techspy - It might be the camera angle, but it looks like your take off angles are a bit shallow. They should be close to 45 degrees. This is important to maintain circularity.
-Alex
Jun 06, 2011, 12:37 PM
techspy's Avatar
Thanks. I will check them again.
Jun 06, 2011, 03:07 PM
Here is the results from the new 5.8 200mw on the funjet with Clover leaf, very happy with the results
BUT... Second video is a previouse one with normal whip antenna's on, the colours seems alot better, with the Clover leaf they look a bit washed out??
Is it maybe just the weather/lighting conditions?
Clover: Processing.................
Funjet with 5.8Ghz and Clover Leaf antenna test (1 min 32 sec)
Whip:
Funjet with KX171 (3 min 47 sec)
Jun 06, 2011, 09:34 PM
FPV Pilot
ttucker's Avatar
Originally Posted by rcimports
Got my antenna's on Friday, Thanks Alex!!
Below is my installation into the funjet, nice and out of the way,
Had a quick flight on staurday and it's waaaayyyyyy better than stock whip's! Video to follow,
Cheers
Dion
What kind of range are you getting?
Jun 06, 2011, 11:09 PM
Oh so close!
clipper99's Avatar
http://www.youtube.com/watch?v=EwS2DO3dl8s
Whip:
http://www.youtube.com/watch?v=WokCLq_1H4Q
Judging from the really long shadows in the first (better colours) video and the much shorter shadows in the 2nd video I would say it is all down to lighting. Much better contrast at the time of day for the 1st video, perhaps even bordering on the "golden hour". Next time do a quick swap of the antennas and then compare and the PQ should be the same.
cheers
Jun 07, 2011, 05:03 AM
Originally Posted by IBCrazy
Several things:
#3: you are using Fatsharks (which likely have an Airwave module in them). There are known issues with airwave modules.
-Alex
Hi,
Whats with the Airwave modules? Is there a problem with tx or rx? And is there a way to overcome these issues?
I'm looking into buying ImmersionsRC 5.8 600mW tx (can't decide on rx)
Would CL/SPW combo be good for that?
Jun 07, 2011, 05:16 AM
Flying low is expensive.
pdiddyg40's Avatar
Clipper99: What exactly defines the "golden hour"? I imagine it's just the time of day where the lighting is perfect for some good FPV, but when is this?
Jun 07, 2011, 06:36 AM
Engineer for Christ
IBCrazy's Avatar
Originally Posted by aSa2
Hi,
It's only the 2.4GHz airwave modules that have an issue. I can't remember which ones. Again, it's a sync problem like I had with the Lawmates. Without testing, I can't figure our how exactly to fix it.
There are no known issue with 5.8GHz.
-Alex
Jun 07, 2011, 08:55 AM
Haven't really pushed it, clear up to about 300m
Jun 07, 2011, 09:01 AM
-Alex
I have 2.4Ghz 100mW FatShark tx and FatShark googles with built in rx and have no luck with CL on rx and SPW on rx, how ever I got good results with SPW on tx and whip on rx, could not say that i got better range, but got almost no multipath problems
It could also be the matter of antennas as I made them my self and have no equipment to tune them
Jun 07, 2011, 05:46 PM
Multi-Rotor Pilot
tkeeg's Avatar
Video Transmission Quality Question
Hi Guys,
For those of you who have used different frequencies of video transmitters, I have a question. A friend of mine with a lot of FPV experience says that he has noticed a distinct difference in the video quality being transmitted from the same camera when using a 900MHz and a 1.3MHz transmitter & receiver setup. He states that the video picture is of a noticeably lesser quality when being sent through the 1.3MHz transmitter & receiver setup than with the 900MHz transmitter & receiver.
Has anyone experienced this phenomenon ?
Tom
Jun 07, 2011, 06:18 PM
Engineer for Christ
IBCrazy's Avatar
http://www.youtube.com/user/CAGreve1.../0/Y0vWmL_o4Vg
Jun 07, 2011, 07:57 PM
I don't get any sound at all from that. It *looks* like you are explaining something... ;P
Looks like an neat way to assemble the cloverleaf.
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2438 Sep 18, 2017 09:25 PM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 463 Apr 27, 2017 05:46 PM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 360 Aug 08, 2016 10:44 AM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
