Build Log
HobbyKing Tristania-EPP High-Performance 3D Airplane w/ Motor
HobbyKing Tristania-EPP High-Performance 3D Airplane w/ Motor (USA Warehouse)
New Video Added 3/29/2011
A lightweight and agile high performance 3D plane that will push your skills to the limits! Reinforced with CF, and complete with option fins for precision tracking, this plane is designed for ultimate 3D and beyond! This kit includes a 3D ready motor, prop saver and propeller. Spec. Fuselage length: 895mm WingSpan: 845mm ARF Weight: 190~210g Included. Motor : T2006 1900kV Brushless outrunner Airscrew : 8040 slow flyer Setup used for my model Battery : 2 cell 7. 4 volt 250-350mah (25-30C) packs Servo : 4 x 5g servos ESC : 10 amp esc Your own TX & RX |
More Pictures
Here are more pictures of the build.
We are waiting breathlessly for a flight report. Would you please try to compare it to the SuperSlofly28 that we are used to flying?
Also useful would be some commentary about the build. Any tips or tricks? Difficulties you ran into? Must not have been any since you finished it so quickly. |
Some quick notes that i can tell you so far plane came in at 6.1 oz without a battery pack installed, plane looks awsome the pictures don't do it justice, I modiifed from the plans a little and put the battery on the top of the fuselage as the required position makes the plane Nose heavy. will try and get a quick video up later.
I am gonna pull the trigger on one of these shortly. What are you guys using for Batts? I have some TP 3S 730s that hopefully will fit the bill.
Jeff |
More Pictures
Plane is 100% RTF came in at 6.1 oz without the battery pack
I was going for 7.0oz auw and hit my goal |
First Hover Still
Here is a Video still of the first Hover! Plane might be a little under powered wont know until I get the little guy outside on Sunday!
Thread Tools | |
Similar Threads | |||||
New Product | Nanoshark ARF- Build Log - High Performance Depron Airplane | NanoDave | Foamies (Kits) | 143 | Sep 08, 2015 08:29 AM |
New Product | HobbyKing Tristania-EPP High-Performance 3D Airplane with motor | CrashingDutchman | 3D Foamies | 174 | Aug 15, 2015 08:27 PM |
For Sale | Exceed RC Mini 50MM 2.4Ghz MIG-15 High Performance Ducted Fan Jet w/ Brushless Motor/ | Mikey 68 | Aircraft - Electric - Jets (FS/W) | 14 | Mar 26, 2012 07:49 PM |
For Sale | RTF Nanoshark high performance Depron airplane | NanoDave | Aircraft - Electric - Airplanes (FS/W) | 14 | Dec 24, 2010 02:16 PM |
New Product | HobbyKing Tristania-EPP with motor | CrashingDutchman | 3D Flying | 2 | Jun 15, 2010 09:08 AM |
