Feb 06, 2011, 06:29 AM
destructive testing expert
dcaspi's Avatar
ESC setup for multirotors
Hi,
In multirotors, you want your ESC to be as dumb as possible, as all the smart work is done by the flight controller. Specifically, it is a really bad idea if an ESC cuts off the motor due to low battery (while the other ESCs may still think the voltage is within limits). To achieve this, I programmed my ESC with the following setup:
- NiMH battery (though in reality I use LiPo)
- Low cutoff voltage
The combination of the above should set up the cutoff voltage to 0 volts.
Low voltage alarm / protection will be taken care off by the flight controller and/or separate card.
The ESC I use is Turnigy Plush 18A.
What do you think of this setup? What do you think of the other setup items (see programming card picture below)?
Dror
Feb 06, 2011, 07:39 AM
Member FPV UK
IWCoburg's Avatar
When I was making gyro only tricopters I had the same setup as you show, but I set the throttle timing to low in stead of the middle you have set. That said, now I am using flight controllers, high seems to give the me the better performance.
Mike.
Feb 06, 2011, 08:16 AM
High gives me smoother starting motors.
Feb 06, 2011, 08:59 AM
dcaspi, thanks for the tip, I'll test it on my rig today.
Is it true that high timing reduces the efficiency (i.e. makes the ESC heat up more)?
Feb 06, 2011, 10:03 AM
A man with too many toys
I always use low timing for RCTimer and HK motors. It gives me a little more flight time and cooler running ESC’s and motors.
Feb 06, 2011, 11:13 AM
Neat, it really cuts off close to zero
Regarding the timing vs. power issue: Turnigy Plush 25A at High Timing eats about 960 mA, while Low Timing consumes only 920 mA at the same throttle. The difference is measurable, but insignificant. It's less than 5% difference. I observed much less clicking and throttle fluctuations at high timing though.
Feb 06, 2011, 12:23 PM
If you overdraw a lipo it will ruin it in short order. That's why they have low voltage cutoffs built into esc's
Feb 06, 2011, 12:40 PM
Zirt57's Avatar
Yes but this is a multi-copter, not a plane. We would rather sacrifice a battery rather than a quad/camera. I set a timer and have a lipo alarm but if for some reason I get in trouble and have to fly below the lipo's cut-off, so be it.
- Jeff
Feb 06, 2011, 01:11 PM
Exactly. Without a cutoff you might ruin a lipo. Total cost: $50. With a cutoff you will save the lipo for about two seconds, before it hits the ground like a rock, destroying your quad and the lipo. Total cost: >$500.
Aug 23, 2015, 07:46 PM
It's mine now, I took it apart
RCFanatic845's Avatar
Speaking of cutoffs, what is the voltage that these 18a escs cut off at when set to the 'low' setting on the card? I'd like to set my lipo alarm to go off about a minute before my tri drops from the sky.
RCF
Discussion HobbyKing 35A fixed wing ESC setup for dual edf's PanamaDan Power Systems 3 Dec 28, 2010 05:27 AM
Help! Connecting 2 esc's for twin edf setup nomadic80 Beginner Training Area (Aircraft-Electric) 7 Dec 23, 2010 09:49 PM
Discussion Esc setup help needed for e-sailplane Tim Konuch Electric Sailplanes 11 Dec 20, 2010 11:42 PM
Discussion Need help choosing motor/esc for twin 70mm setup. ChrisG23 Foamy EDFs 0 Dec 02, 2010 10:49 PM
Discussion ESC vs. transmitter for throttle curve setup Butthead Power Systems 4 Dec 02, 2010 08:08 AM
