May 09, 2017, 09:04 AM
Fly and let Fly!
Cocg's Avatar
Originally Posted by Cubcrazy
Winds at 0 gusting to 1.
May 15, 2017, 08:34 AM
shadowbreaker's Avatar
A little 182 style floatin this morning.
Wow that water looks really stunning!
May 18, 2017, 03:56 AM
Hi all,
I just got one of these and spent the afternoon assembling it. Looks great and can't wait to fly it.
But, I've attached a pic, it looks to me like the engine mount may be bent. The cowl is sitting on snug in position and the engine is clearly off center. Just wondering if I should take the mount off and try to straighten it or is it not that critical and I'll be able to trim it out?
I'm new to this and having visions of flying endless left turn circles. haha
thanks
Mark
May 18, 2017, 04:16 AM
Scale Foam Flyer
Cubcrazy's Avatar
Originally Posted by markoreb
Hi all,
thanks
Mark
It looks like the motor mount may have been installed upside down at the factory. Try taking it off and flipping it. Thrust angle should be to the right to compensate for torque.
Latest blog entry: From the CC Paint Shop
May 18, 2017, 04:58 AM
Hi, thanks for the suggestion. I had a look at that and the mount holes are drilled in such a way that it can only be attached one way.
cheers
Mark
May 18, 2017, 05:04 AM
Scale Foam Flyer
Cubcrazy's Avatar
I would just install some tiny washers behind the motor mounts to re-direct the mount the way I want it. I highly doubt that it is bent...more like made wrong.
May 18, 2017, 03:40 PM
formontoya's Avatar
or check the plastic firewall to see if it's damaged in shipping.
May 18, 2017, 04:13 PM
Maybe I'm just over analyzing. There's no apparent damage. Time will tell.
thanks
Mark
May 18, 2017, 11:13 PM
Out of the Past
That prop shaft SHOULD be off center, BUT, to the other side, for Right Thrust. You had best correct it.
Take the cowl off. Look straight down at the mount and motor. It should be pointed a few degrees to the right from the firewall.
DUCK
Yesterday, 02:53 PM
Hello RC friends,
I am considering ordering one of these (banggood Sonicmodell Cessna 182 V2) planes but the places where I fly are either grass or rocky dirt.
Are these wheels big enough to land on rough terrain or am I going to nose it every time I land?
One other question: If I do order one, what would an appropriate 2 blade propeller be if my 3-blade prop breaks?
The plane looks really nice!
Yesterday, 03:56 PM
BobW55's Avatar
One (1) inch larger in diameter, same pitch for the prop.
Be aware your prop will be 1/2 inch Closer to the ground.
I fly off a grass field and have trouble if not freshly mowed. I have given thought to mounting tundra tires on mine.
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 833 Feb 04, 2017 06:19 PM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 17 Jul 31, 2016 08:57 AM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 04:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 05:15 PM
