Oct 23, 2013, 07:33 PM
Acft Attn Deficit Disorder
Cubcrazy's Avatar
BTW P-Fitty,
I just went back and looked at all of you pics on the water. AWESOME!!!
-CC
Oct 23, 2013, 07:34 PM
P-51 flyby's Avatar
Alright taken with my gfs crappy PHD camera but here they are. I used wire coat hangars and scrap aluminum with loctie epoxy and a lot of pressure to fit them.
Oct 23, 2013, 07:38 PM
P-51 flyby's Avatar
Originally Posted by Cubcrazy View Post
BTW P-Fitty,
-CC
Thanks brother! I owe ya one for the help with her..when I bought the bird in Jan. I was going to toss the flyzone floats on her but I wouldnt have known crap about floats without ya on it. I hate I procrastinated so long to do it...this bird rocks of floats.
This was from a week or two ago doing the first float test....you see after I make the downwind turn on the water what will happen if I dont give her some up ele. Since then I have adjusted the water rudders to be smoother as well she tracks like an arrow now.
FMS/Airfield Cessna 182 on flyzone beaver floats first taxi run! (0 min 42 sec)
Oct 23, 2013, 08:28 PM
race58's Avatar
Thanks guys for your help ,, that's what needed to finish.
Off to LHS tomorrow then I will test taxing on the water. Feel safer doing that with the added insurance of a revovery boat.
Ed
Oct 23, 2013, 08:43 PM
Cubcrazy's Avatar
Just remember..you can taxi on the step, and you can taxi slow..try to taxi around in the middle speed, and things can go south pretty quick.
-CC
Oct 23, 2013, 10:05 PM
race58's Avatar
Ok thanks,, I'll try to remember that but ya know that CRS
Oct 24, 2013, 12:14 PM
race58's Avatar
The step of the float should be in vertical alignment with the CG of your airplane.
+ or -. You want your float angle of attack to be such that your wings are slightly positive (leading edge up) to the flat portion of the floats. If your wings are not pointed a couple degrees up, It will be harder to get up on the step when taking off.
-CC
How does this look for intial alignment before bracing?
Oct 24, 2013, 02:51 PM
Cubcrazy's Avatar
The step position looks great. I assume that you are going to install diagonal struts and cross "wires" in the front? I tried flying mine without the cross wires in the front. It made a huge difference to add them. Really stiffened things up in the roll axis. The diagonal braces take care of pitch movement, so with both, it's a really clean and rock solid setup.
Good Job,
-CC
Oct 24, 2013, 03:46 PM
race58's Avatar
Oh yes I'm going to brace it. Just wanted to make sure before I locked it down.
How's the angle on float to wing?
I also have a plan to use the nose gear strut and servo to operate the water rudders. When I get it laid out I will post pictures.
Ed
Oct 24, 2013, 05:36 PM
Cubcrazy's Avatar
Float angle looks good from here
-CC
Oct 24, 2013, 06:00 PM
race58's Avatar
Thanks full speed ahead into the unknown.
Ed
Oct 24, 2013, 06:44 PM
johnd
... door to hatch for dock lines! I love it!
Oct 25, 2013, 02:24 PM
race58's Avatar
Ok I just noticed something and have a question for you guys.
It deals with the bracing on the sides. Some I see have the brace going from top front to rear bottom while others do it the other way bottom front to top rear,
I have seen both on fullsize 182's as well.
Is there a reason to do it one way or the other for distributing stress on landings and TO's or is it just personal preference?
Ed
Oct 25, 2013, 02:32 PM
P-51 flyby's Avatar
Lol..thanks and wheel chocks when I get her back to gears
Oct 25, 2013, 02:33 PM
P-51 flyby's Avatar
Ed
Not sure. The ones ive seen that go bottom front to top rear are normally on the 206 and 208's
Discussion Dynam Sky Trainer Cessna 182 dbc Foamies (Kits) 847 Jul 23, 2020 09:25 PM
Question Nitoplanes Airfield RC 55 Trainer $139.00 hyed Beginner Training Area (Aircraft-Electric) 17 Jul 31, 2016 08:57 AM
Discussion New Airfield Cessna 182 Sky Trainer w/ Lights and flaps al18r21 Electric Plane Talk 93 Dec 27, 2014 05:31 AM
New Product New Airfield Cessna 182 skytrainer nitroplanes Scale Kit/Scratch Built 323 Apr 01, 2012 09:33 AM
Sold Nitro Planes Foam AirField Cessna Skyline 182 - 55" Trainer "RTF" $100 FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 12 Feb 10, 2010 06:15 PM
