Jul 16, 2019, 10:19 AM
You down with EPP?
johnnyrocco123's Avatar
My setup I discovered long ago, and I could never find anything that was as fast.
3659-1900kv APC 7x6 Gas prop, 4s 3300mah 70C
https://hobbyking.com/en_us/turnigy-...-90mm-edf.html
Jul 16, 2019, 01:10 PM
Julian T
Yes, I can't see much exceeding that in a DF. Wish I had tried it before mine expired in a midair. Any estimate as to straight and level speed? And how did you get the 3300 in - the most I ever squeezed into a DF was 2600 4s and that involved removing a fair amount of foam.
Jul 16, 2019, 01:13 PM
You down with EPP?
No foam removed. a 4s 3300mah fits perfectly. Nothing bigger
I think it was clocked at 125-130mph years ago with that setup. I use the Roaringtop 4s 3300mah 70C
Jul 16, 2019, 01:14 PM
You down with EPP?
The only way it will balance with that big battery in it is with the heavy motor up front
Jul 16, 2019, 01:41 PM
Registered Foam Abuser
jiggiba's Avatar
I tried that motor in one. It was fast but kinda heavy. If I remember correctly it died on a bad hand launch.
Jul 16, 2019, 04:48 PM
GryphonRCU's Avatar
Neons,
Not sure if you are still looking for a motor or not.
For serious performance, consider HET 650 series.
250 gram $99
300 gram $109
My RCGroups PM is down.
Instead, Email me if you want help with motors.
Gryphon
Jul 16, 2019, 10:40 PM
**neons**'s Avatar
Gryphon,
I have a motor on the way. Maybe next Monday. I was happy under 100mph with a 4s lipoly I do have a HET Typhoon in another plane. Great motor.
ThanX
Jul 17, 2019, 06:07 AM
GryphonRCU's Avatar
When you are ready for 4S at 200+A look me up.
(While running 7 prop)
G.
Jul 17, 2019, 08:19 AM
tware's Avatar
G.
[looks up, sees ailerons and elevators slowly fluttering to the ground]
Aug 22, 2019, 10:27 AM
#who gives a rats a**?
feefo's Avatar
Originally Posted by **neons**
Gryphon,
ThanX
Personally I think you're better off with a lower kv motor and a bigger prop, 6" prop looked too small for me. I use a Scorpion 3026 I think it is on 4s and used 8x7, 8x6, 7x8, 7x7 and 7x6 sport props. I'd consider the EFXtra motor on 4s and a 7x6 in the DF if I needed another motor and wanted to keep cost down
https://hobbyking.com/en_us/aerostar...ess-motor.html
Aug 22, 2019, 11:22 AM
**neons**'s Avatar
I have another motor coming. I will drop the Kv if this one does not work out. This is my 3rd motor . Burnt 2 already during some nice passes. I flew it back dead stick for another day.
Thanks for the info.
**Neons**Bob
Question Kyosho Phantom Reno Racer Motor Selection Cincy E-Flyer High Performance 6 Aug 12, 2011 03:35 PM
Discussion Multiplex news 2011: Reno-style DOGFIGHTER etc mopetista Foamies (Kits) 0 Feb 01, 2011 07:09 AM
Sold Cox Corsair II Reno Racer CL RTF skylane42 Aircraft - Fuel - Airplanes (FS/W) 0 Dec 11, 2010 11:45 AM
For Sale Hacker Reno Racer-Cosmic Wind Doug Hinkel Aircraft - Electric - Airplanes (FS/W) 1 Sep 02, 2010 01:02 PM
