Jan 03, 2013, 03:54 AM
clipper's Avatar
Any one going to the build night and has a 1.1 to 1.3 meter wing span DLG or slopper please bring so I can see the construction styles and relative strenghts.
Eric
Jan 03, 2013, 03:57 AM
Sane til the lift starts!
kpeevyhouse's Avatar
Originally Posted by sazfone
All you glass painter experts: I'm going to paint my Tucsno pss which already had a paint job from the original owner. What grade sandpapers should I be using to 1. Prep it for primer, then 2. Sand the primer before color?
Chuck
I would use 220 grit to sand off as many layers of the original paint as you want to remove. A flat piece of scrap EPP works great as a sanding block. Then switch to 400 grit to smooth out some of the scratches. Don't worry about removing them all, since the primer should fill most light scratches. If the sandpaper clogs up with paint, then switch brands. Or else wet sand the plane.
After spraying the primer and letting it cure, you can lightly sand it with 400 grit before spraying on the color coats. Lightly re-sand any areas with 400 grit in between color coats. The final coat of paint should fill up any scratches from the 400 grit.
Once all the color is sprayed on, I wipe down the entire plane with #0000 steel wool. This removes any micro-bumps left from overspray and smooths out the surface without really scratching the paint. Then you can add whatever details you want: panel lines, decals, etc. Spray the plane with a clear coat if you want to, and you're done.
Jan 03, 2013, 11:15 AM
Works to Fly
Slopedaddy's Avatar
Thanks Keith!
Jan 03, 2013, 11:32 AM
Rotozuk's Avatar
AMA Expo -
It's that time of the year again. Noticed they have a group rate discount. If we buy 10 tickets at a time, we save $2 ($8 per). You all interested? We would probably all have to show up at about the same time to distribute tickets.
Might I suggest visiting Flo's Cafe on Chino Airport for those attending the event. It is a classic I try to visit whenever I'm in the area. Chino airport is an amazing place too! Maybe we should just plan a OCSS day there sometime in the spring and visit one of the museums there.
-Wayne
Jan 03, 2013, 12:33 PM
Rick T.'s Avatar
Wayne
I am going
rick
Jan 03, 2013, 12:34 PM
Rick T.'s Avatar
Dave
Nice catch on the P40, I was a little late
Rick
Jan 03, 2013, 12:39 PM
Silent Flight
Twyl's Avatar
OT but an FYI to any of you small device collectors out there. Best buy is doing a tradein/recycle promo until 1/19 where you get $5 in Best Buy gift cards for each "small device" you trade in working or NOT. Note that if you don't need anything from Best Buy you can purchase Amazon Kindle Gift Cards there as well which work on anything sold at Amazon so pretty much the same as cash. While the policy notes you can only bring in 3 items per day I wouldn't reminding them about it and just try to do as many as you can if you have more than 3, if they won't take more just bring them back the next day. Best Buy's customer service is notoriously hit and miss if not just outright lame so YMMV some.
Originally Posted by BestBuy
Best Buy® is here to help you start the new year right. Trade in your old tech for something brand new. Get a Best Buy gift card of at least $5¹ when you trade in any small device, working or not.
1 Small device means any product in the following categories: laptops, tablets/eReaders, mobile phones, MP3, gaming hardware (console & handheld), DSLR, digital point & shoot, and digital camcorder. Not all products are eligible for trade-in. Not available in all locations. Trade-in value may vary. Condition, documentation and accessories may affect value. Payment is by Best Buy gift card. You are responsible for removing any data from your product before providing the product for evaluation. You will be required to agree to the terms & conditions. The Best Buy trade-in programs are intended for private, non-commercial use. No dealers. Limit of 3 trade-in transactions per person per day. Best Buy reserves the right to refuse any trade-in for any reason. Learn more about other products accepted for trade-in and see how much they're worth at BestBuy.com/tradein. In store only. Not available in all stores. See a Customer Specialist or BestBuy.com/TradeIn for details. Offer valid through January 19, 2013.
HERE's the link to their offer which would be a good idea to print out and take in with you if you try this. Originally it's an email, so just say you received it as an email and you will be fine.
HERE's
a link to the deal alert thread on the slickdeals website. For any questions on the details read through that thread, post there for questions, or else ask me and I can share my limited experience.
This worked out nicely for me as I have a stash of old cell phones which filter back to me when we roll out new ones at work. Yesterday I traded in 3 old flip phones without chargers without any issue.
-Jonathan
Jan 03, 2013, 12:40 PM
It's not going to build itself
TRISME's Avatar
I've heard of Flo's Cafe too, all good! There is allegedly a real Zero at Chino right now, being restored.
Jan 03, 2013, 01:58 PM
Gasbags & Gussets
jswain's Avatar
fyi...
Originally Posted by Rotozuk
AMA Expo -
.....Might I suggest visiting Flo's Cafe on Chino Airport for those attending the event. It is a classic I try to visit whenever I'm in the area. Chino airport is an amazing place too! Maybe we should just plan a OCSS day there sometime in the spring and visit one of the museums there. -Wayne
Hi Wayne.
they also have a monthly talk+fly also that may interest the group.
js in riverside (living near the flight path of warbirds test flights from planes-of-fame museum)
Jan 03, 2013, 02:22 PM
Rotozuk's Avatar
Actually they have a real Zero that they fly. They may have another they are restoring??? Lets go find out!.
Yes, the talks they do are very good also. I have attended a few in the past. One was with Burt Rutan, and another with an Apollo astronaut.
-Wayne
Jan 03, 2013, 02:36 PM
Silent Flight
Twyl's Avatar
I think I recall someone mentioning they sprayed the strapping tape with 3M77 waited 10~ min and then applied the tape to the EPP. This prevented overspray of 3M77 to unnecessary parts of the wing. How sound is this method? Does it work just as well as 3M77 to the EPP wait 10~ min then applying tape?
-Jonathan
who can find just about anything to be anal about
EDIT: for shits and giggles, I'll post this question to the main board too
Jan 03, 2013, 02:45 PM
TRISME's Avatar
I spray the wing, then apply tape, when I am taping the whole wing. Are you doing laminating film?
Jan 03, 2013, 02:47 PM
Silent Flight
Twyl's Avatar
Yes, this is for the Mamba, will just be taping the LE and gear area followed by 5mil LF.
-Jonathan
Jan 03, 2013, 03:08 PM
Hump or Death?
O.G. Gamesta's Avatar
AMA Expo -
-Wayne
I plan on going Friday. (unless there's surf or wind) Is the group by for a specific day?
I also heard I should bring a wad of cash with me as you can score all types of deals. Is that true?
John
Jan 03, 2013, 03:11 PM
Nothing to see here...
67econoline's Avatar
Jonathon
Just finish it !!
If you keep building a little overspray won't hurt.
Or in the months that pass the glue will deactivate
Rubio
New Indoor RC Club in Orange County, CA OCModels Electric Plane Talk 14 Jan 15, 2024 03:34 PM
Discussion Slope Flying Sites in Orange County ngdbud Slope Soaring 67 Dec 17, 2023 07:26 PM
Sold Medel tech P-47 Orange County, Ca SurfOnH2o Aircraft - Fuel - Airplanes (FS/W) 2 Dec 13, 2010 12:22 PM
Discussion Looking for other BASHERS in the Orange County, Ca area Bulldogs Large Scale Cars 0 Nov 16, 2010 10:36 PM
Discussion Orange County electric/slope flyers ryan v USA - District X 1 Nov 26, 2008 09:13 PM
