Jan 21, 2011, 05:25 PM
Crash it first, Then fly it
Griffindor's Avatar
Quick help- Su-37 plans
Does someone know where i can get a good three-way of a su-37 (not the 47)? the ones i've seen aren't the best. i might be asking for too much, but cross sections would be good.
Jan 21, 2011, 05:37 PM
Griffindor's Avatar
another thing. i've seen this around before, but didn't really paid attention, bc it was irrelevant to me. how would i hook up 2 seperate motors? would i use two different esc (that wouldn't be so good, since they'ed be out of sync), is there a special syncing esc for 2 motors, or do i use one regular esc?
Jan 21, 2011, 05:39 PM
The lunatic is on the grass
ridgewalker's Avatar
If you have two brushless motors then you need two esc.
Ridgewalker
Jan 21, 2011, 05:48 PM
Griffindor's Avatar
thanks. ill sift through those views. my computer is very old, so something isn't working with my google search. Thanks.
Jan 21, 2011, 05:49 PM
Griffindor's Avatar
That's what i was thinking about the two esc's. i wasn't too sure,so i had to ask
Jan 21, 2011, 05:59 PM
No problem!
Oh....i feel your pain with the old pc......till about a month ago i was still on a dial up connection and running windows 95 !
I could not veiw vid and it would take for ever...if at all for images to load on goggle searc image.
Now on broadband i watch all kinds of vids of planes...it's a whole new word now!
I have not used two esc in a plane but i have done it with rc trucks.
I would use a Y cable plug both esc into the Y and then into the throt on the rx....i always removed the red wire on the esc plug from one of the esc's....of course each esc had it's own battery.
If you try a couple searches here in this forum you probably can come up with better info on the subject than i can give...more directed toward a plane.
Ridgewalker
Jan 21, 2011, 06:03 PM
Griffindor's Avatar
right. thanks. im assuming it would work for a plane too, but there's a 3rd dimension, so things might be different.
Jan 21, 2011, 06:09 PM
Flying high
billwhit's Avatar
IMO, it's best to keep the two ESCs and motors matching. That was they can be taken out of the equation if the thrust doesn't match up. Like ridgewalker said, I've used a y cable to get them both on the same channel. I've heard it recommended to remove one of the red wires, but I've done this a few times now without removing one and never noticed a problem (but different ESCs may need it done). You can also use a y cable and have them both running from the same battery (again, I would stick with this method so both controllers are getting the same voltage).
Jan 21, 2011, 06:19 PM
I found this..https://www.rcgroups.com/forums/showthread.php?t=666686
And these........
Ridgewalker
Jan 21, 2011, 07:07 PM
Griffindor's Avatar
thanks guys. i saw that forum before, and it helped me in a way.
Jan 22, 2011, 02:44 AM
Unregistered User
liam2317's Avatar
Definitely cut the red wire from one of your ESCs!
Jan 22, 2011, 04:26 AM
a good article to read from my friend at our club.
http://www.peterangus.pwp.blueyonder...0multi%20b.htm
this is 4 motors but the principal is the same for 2
Jan 23, 2011, 09:36 PM
Zen in the art of foam
djacob7's Avatar
If any of you have 3D glasses (red/blue), take a look at this 2D to 3D conversion I made several years ago. I didn't know at the time that it was a SU-37. Thanks for the pics, Ridgewalker!
Jan 24, 2011, 01:45 AM
Unregistered User
liam2317's Avatar
djacob7, that is definitely an F15 Hornet, not a SU-37.
New Product 6mmFlyRC Profile Sukhoi Su-37 with Simple Thrust Vectoring (with plans) tomhe Pusher Prop Jet Models 407 Mar 03, 2018 01:51 PM
Video Su-37 after plans by Jetset44 with retracts, mishaps and success Low Pass Electric Plane Talk 3 Oct 27, 2009 09:10 PM
Wanted looking for large su 27/35/37 plans/kit/arf INCARUS Aircraft - Electric - Jets (FS/W) 1 Aug 18, 2009 03:32 PM
Discussion Quick build F-22, SU-37, F-18etc electriceye Pusher Prop Jet Models 6 Jan 27, 2008 12:07 PM
