Jan 21, 2011, 04:04 AM
DomAll
3536 Rewind
Hi,
I have some 3536 motors (2814 stator) with 12 stator teeth and 14 magnet poles, I would like to rewind one to have 2800 kv and ~40 A with a 5x5 or 4.75x4.75 prop like the Axi2814/6.
Do you think it's possible, maybe with Delta connection ?
Thanks for your help.
Jan 21, 2011, 11:39 AM
Jack
jackerbes's Avatar
Which motors are they?
If you have already stripped the stators and know the turn count, termination, and Kv it was advertised to have you can enter that in a turn calculator and it will give predicted Kv's for other turn counts and terminations.
I am thoroughly addicted to the use of manuel_v's Turn Calculator 5 which is free for the download at the link.
If you don't have Excel you can download the free OpenOffice.org suite and use the Calc application to run the spreadsheet.
If you know the turn count, termination, and Kv and post it I can post an image of the spreadsheet result it you'd like. Or post the make and model and maybe we can find the info.
Jack
Jan 21, 2011, 11:44 AM
Jack
jackerbes's Avatar
Look what I just found!
"Rewind HXT 3536-1000 (2814 mm stator)" - https://www.rcgroups.com/forums/showthread.php?t=923854
I thought I had seen something like that here before, 3536 did not come up in the forum search tool but I googled it and it did come up.
You can use the results others have gotten to feed the spreadsheet and close in on the wind you want.
Jack
Jan 21, 2011, 06:26 PM
DomAll
Hello Jack
Most are Turnigy 3536 1450kv, in this size it's very difficult to find a motor with 2800kv like the Axi2814/6.
I will follow the links you give me and look Turn calculator.
Jan 25, 2011, 06:16 PM
Fourdan's Avatar
Originally Posted by Dom Allart
Hi,
Hi
Try 3 turns per tooth Delta dLRK (6 t per pair that is 6 conductors per slot)
Preliminary test for filling the slots by choosing wire AWG & #strands
Then rewind and test the Kv
Louis
Jan 25, 2011, 08:09 PM
DomAll
Hello Louis,
I will try it, now I'm just reading powercroco website to know what size of wire I will use.
Discussion rewind the keda 22-20L 9XTremist Electric Power Systems 0 Dec 09, 2010 03:24 PM
Discussion More Heat in Motor After a Rewind Chuchuf Electric Motor Design and Construction 22 Dec 06, 2010 09:16 AM
Sold G&C 3536 Motor from FMSModel ZackJones Aircraft - Electric - Power Systems (FS/W) 3 Oct 20, 2010 09:38 AM
Sold Speed control, turnigy 3536 alextronique Aircraft - Electric - Power Systems (FS/W) 2 Sep 05, 2010 06:00 PM
Discussion Rewind HXT 3536-1000 (2814 mm stator) _King_Pin_ Electric Motor Design and Construction 10 Sep 22, 2008 03:43 PM
