How to charge Turnigy AA LSD 2200mah Low Self Discharge Cells - RC Groups
Jan 16, 2011, 04:01 AM
Here i took pics of batteries, wall charger and Transmitter battery Holder.
The specs of cells are AA
There are 8 cells all are 1.2 V
5 cells are 2000 mah and 3 are 2500 mah
The pics of cell are
The Pics of Wall charger are
The Transmitter i am using is
Hobby King 2.4Ghz 6Ch Tx & Rx V2 (Mode 2) http://www.hobbyking.com/hobbyking/s...idProduct=9042
The pic of battery holder of transmitter is
As you can see the transmitter specs says 1.5 v However i have cells of 1.2 V.
8 cells x 1.5 V = 12 V
8 cells x 1.2 v = 9.6 V
As you can see the wall charger pics. Its output is 12 v which is higher than 9.6 V
If i connect it with transmitter charger port will it dangerous? I dont wana take risk
Please Reply soon
Jan 16, 2011, 05:57 AM
You shouldnt be mixing and matching different cell types or capacities, grab 8 matched cells and you can charge them
A fully charged AA cell is around 1.45 - 1.5v when full (making the 12v charger ok to use)
It's safer to charge them seperately outside of the TX but plenty do it with no issue, including myself
Cheers
Jan 16, 2011, 08:59 AM
ok i am going to buy
Turnigy Accucel-6 50W 6A
http://www.hobbyking.com/hobbyking/s...idProduct=7028
to charge these cells.
But dont know how to do. Do i need holder? Which type of accessory do i need to buy which can hold and charge them. Please recommend me from http://www.hobbyking.com because they ship to my country at economical price
Jan 16, 2011, 09:20 AM
Southern Pride
everydayflyer's Avatar
Purchase 8 each AA NiMH cells (batteries) place them i your transmitter and charge them withg a stsndard RC Transmitter / Receiver charger such as comes standard with most RC systems.
The Sanyo Eneloop AA low self discharge batteries are perhaps the best but others will work also. Best to not use ones with greater than 2300 mAh capacity however.
All about AA NiMh cells in Transmitterss
https://www.rcgroups.com/forums/showthread.php?t=327288
Charles
Jan 16, 2011, 03:17 PM
If you are charging AA/AAA on a consistent basis then something like the La Crosse BC-900/BC-700 or the Maha C9000 charger is a great investment. The two main benefits of these chargers is they charge each cell individually and they can cycle the cells. When charging my transmitter batteries each week I set them to discharge first and the automatically charge. This prevents any memory effect that you will see with something like a wall wart charger or the $10 AA/AAA chargers. I personally have 2 of the La Crosse units so I can charge 8 batteries at once.
Now with that said you should always have a wall wart charger in your box so you can easily charge at the field/race track if needed.
Help! How To charge and discharge TraxxasslashVXL Electric Power Cars 4 Dec 10, 2010 04:03 PM
For Sale x2 Turnigy Nanotech 5000mah 3s | 45-90C Discharge | 10c CHARGE RATE Sl0flyer Cars - Cars and Parts (FS/W) 0 Nov 15, 2010 08:57 AM
Question How do I charge eneloop cells with this? INCARUS Batteries and Chargers 7 Oct 27, 2010 09:30 AM
Discussion AA LSD charge rate ?? 1101 Batteries and Chargers 1 Feb 12, 2010 09:41 PM
'New' Sanyo NiMh with very low self-discharge rate Peter Khor Batteries and Chargers 1 Nov 09, 2005 08:48 PM
