This thread is privately moderated by phil alvirez, who may elect to delete unwanted replies.
Jan 12, 2011, 09:39 AM
classic Elf 20" (stick-n-tissue)
as this blog is getting too long, i better keep adding here on top what's new. easier to see it. thanks for your interest.
NEW:
jan 15
am starting a thread on 'motors for ultra micro models with 6400 brick'. give a look to it and bring your comments and contribution
https://www.rcgroups.com/forums/show...php?t=1368507s.
january 12, 2011
Classic Elf 20" (stick-n-tissue)
100 sq in, 50 grams auw, for 4s/suk components.
i spent the past 5 weeks working as hard as i could, re-designing the structure of the Elf 20" for balsa stick and tissue, building it, and just finished it. i have been doing foamies for the past who-knows-how-long, and finally went back to balsa. i decided to have 2 planes based on same design, same basic dimensions, 1 foam, the other balsa, and compare them.
so far, what i have to say is that, as we could expect, foamies build way faster, don't require as much skills or precision; take more punishment, and are easier to repair. what i was not expecting is that foamies are lighter than balsa planes, even stick and tissue: the foam Elf 20 weighs 42 grams auw, and the balsa 50. now, i still have to fly them, to learn what the difference in flight is, although that has to be indoor at the time, and in a hurry, because the boys at the gym only let light stuff for a few minutes.(update: maiden flight: see the thread at indoor and micro models-link below)
>>here are some details of the build: airframe: same wing planform (20"x5"=100 sqin), edges are 1/16 x1/8 balsa with 1/16 sq spruce=1/16x3/16-sanded wedge shaped (yes, sharp); 2x1/16 sq spars over/under; 1/32 c grain ribs with geodetic structure=no warps. wing attached with rubber bands. fuse/tail: 1/16x3/32 and diagonals all over. covering is transparent blue microlite, except transparent red ultracote lite on top of wing/tail, clear microlite on bottom surfaces and windows. .048" (3/64") landing gear, 1.23" dubro wheels; .8mm cf pushrods. glued mainly with ambroid. avionics are from sukhoi: 8.5 geared motor, 130/70 (5.1") prop; 6400 brick, cells from 110 to 160-maybe even 240, as the cell goes at the cg.
and steerable tailwheel from the suk! auw 50 grams with a nano 160.
more details on the thread at indoor and micro models:
https://www.rcgroups.com/forums/show....php?t=1370558
Jan 20, 2011, 11:55 AM
No Guts No Glory
kestrel2003's Avatar
Love the geodetic wing
I realy like the geodetic wing. Cheers mv
Jan 20, 2011, 01:28 PM
no warps
thanks.
you don't see many like that.
lots of time spent doing precise joints, but it's worth it, as is the way to get the lightest warp free structure-and once finished it is there, the most pleasing to the eye-at least to me, and guys like you.
Discussion What's for x-mas,what's your winter build? Dark Angel Foamy EDFs 6 Dec 10, 2010 11:52 PM
Discussion What's new news about Anka? Nīmā UAV - Unmanned Aerial Vehicles 20 Nov 16, 2010 04:24 AM
Discussion What's new and interesting in your modeling? Mr. Wiz Electric Plane Talk 29 Sep 28, 2010 07:24 AM
Discussion Been out of hobby for awhile. What's new in lipos? Toker Batteries and Chargers 10 Sep 16, 2010 09:56 PM
Discussion Discussion:what's hit heli now?or what's new now?? enjoyhobbies Electric Heli Talk 7 Sep 01, 2008 08:09 PM
