Jan 11, 2011, 10:04 PM
8000 Watt Club
Geoff Dryer's Avatar
Build Log
50% Electric J3 Cub (Clipped Wing)
It has been 30 years since I built my last plane from scratch, but I have decided to embark on building a Big Cub to be powered by a Hacker A-100.
Why?
I am fond of flying scale aircraft and I love flying my 25% RC Guys Decathlon. I have pondered something larger after first seeing video of the Hempel Cubs (http://www.billhempel.com/cub.html).
I would buy a Hempel Cub in a heartbeat but:
1) I do not own a 12 foot long trailer and I cannot see me getting that one by the wife. Also my garage is too short for a trailer. My workaround will be a two piece fuselage.
2) The Hempel Cub is designed to stand the rigors of a 150cc gas motor and is a little therefore a little bit heavier built than would be required for a 100cc equivalent electric motor.
3) I want the challenge of building most of the plane from scratch.
I have a good friend (a very good stick builder) who is going to work with me on the build. He has built several 25% and one 33% Balsa USA Cub. We have come up with a plan that incorporates the best features of both plans. I had a set of 25% plans blown up and printed at 200%
What
Here is my tentative plan:
50% scale clipped wing J3 Cub
- Wingspan: 180 inches (foam core wings)
- Wing chord: 32 inches
- Wing thickness: 3.75 inches
- Horizontal stabilizer span: 60 inches
- Fuselage length (2 piece): 134 inches (to front of cowl)
- Rudder height: 25 inches
- Total height: 42 inches (on 8.5 inch wheels)
- Hacker A-100 motor (7500 watts)
- Target weight: 50 pounds
Although this color scheme has been done my many others, I have always been fond of the Hazel Sig blue and white scheme. This was a true clipped wing J3 so this will be scale.
Have a read here (http://www.avweb.com/news/profiles/182140-1.html) to learn more about Hazel Sig.
Jan 11, 2011, 10:15 PM
8000 Watt Club
Earlier I stated that my garage was too short for a full size cargo trailer. What I meant was that the door opening is only 7 feet high. Changing this involves spending a whole lot of money.
I current have a trailer box (8 ft x 4 ft x 3 ft high) that fits on a folding utility trailer. my plan is for that the two piece fuselage with removable horizontal stabilizers and folding landing gear should fit in this box.
Jan 11, 2011, 10:42 PM
*crunch*
forevercat's Avatar
sounds good! subscribed
Jan 12, 2011, 12:02 AM
aka Schleppmeister
good luck with your project!
http://www.iflytailies.com/
Jan 12, 2011, 09:18 AM
Just Plane Nuts
Louierc's Avatar
Subscribed! I am working on my second 1/3 scale e-Cub (Hacker A60) and keep looking at the Hemple 50% Cubs - thinking that would be a great idea. I have a friend with a 50% plane, and it is big to transport and assemble - takes extra help and a trailer. The 1/3 Cub (144" span) will just fit in my mini van. You might look at the 12' Telemaster, which has the two piece fuse, to see how they do it.
Jan 12, 2011, 11:01 AM
8000 Watt Club
I looked at the Telemaster and couple of other projects that use a joined fuselage. There is also a short thread here: https://www.rcgroups.com/forums/show...ight=two+piece
I am planning on using plywood on each side and a short piece of carbon fiber tube with 4 bolts and blind nuts.
Jan 12, 2011, 01:12 PM
supercubman's Avatar
Geoff, I will be following along!! I have had a few thoughts myself of building a 40-50% supercub. I am finishing up on a 25% sc right now https://www.rcgroups.com/forums/show...+scale+top+cub and was thinking the other day how much fun it would be to build one like this in a larger scale. At any rate good luck I will be watching from here on out!!
Trey
Jan 12, 2011, 02:16 PM
8000 Watt Club
Trey
I had not seen your thread before. You skills show in the finished product!
I was interested in the CAD generated PA-18 instrument panel that you found. Can you point me to it?
Jan 12, 2011, 02:58 PM
Great project. Do a google for, wings and wheels 2009 Ali Machinchy half scale cub. I was there and the video does not do the flight justice. It is a Bill Hemple 50% c/w cub and uses a ZDZ 210cc engine and weighs 50lbs. It is obviously overpowered! At least you will not need to fit an onboard starter!
Good luck and every success with the project.
Chris.....UK
Jan 12, 2011, 03:55 PM
8000 Watt Club
Chris.....UK
I had actually seen that video before. OMG he really throws that Cub around. The announcer said that it was 70 lbs which sounds about right with a ZDZ 210.
Ali Machinchy - Half Scale Cub (7 min 47 sec)
Jan 12, 2011, 03:59 PM
Geoff, here it is...........
Trey
http://www.3pointaircraft.com/3point...ews/sc_pnl.gif
Jan 12, 2011, 04:48 PM
8000 Watt Club
This was the dash from the Cub that I visited. It was a lot simpler. (More pictures later)
Jan 12, 2011, 07:03 PM
This sounds fun Geoff. What spec batteries etc?
Rog
Jan 12, 2011, 09:47 PM
8000 Watt Club
Rog
Electronics
Hacker A100-10 motor (27x10 Xoar propeller)
Hacker Masterspin 170 speed controller
4 x 6S 5800 mAh Turnigy 30C batteries (12Sx2P)
Ailerons (2 per side) Hitec HS-7950TH (400 oz inch @ 6V)
Elevator (1 per half) Hitec HS-7950TH (400 oz inch @ 6V)
Rudder Hitec HS-7980TH (500 oz inch @ 6V)
2 x Duralite 2300 mAh A123 batteries
Smart-Fly EQ-10 power expander
Smart-Fly pin and flag failsafe switch
Hitec Optima 9 receiver
Jan 13, 2011, 05:46 AM
Thanks Geoff. What do you use to charge 4 x 6S LiPo's?
Rog
Discussion CMPro Clipped Wing J3 Piper Cub 65" WS djmoose Scale ARF/RTF 5 Sep 26, 2010 07:18 AM
Build Log Clipped wing cub 48 by Wing Maker Dakrat Glow to Electric Conversions 23 Sep 15, 2010 04:35 AM
Wanted Dave Patrick PA-18 1/4 Scale Clipped Wing Super Cub RMS Aircraft - Fuel - Airplanes (FS/W) 0 Aug 31, 2010 01:22 PM
For Sale Wing for Sig Clipped wing J3 Cub TTT1111 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 26, 2010 04:08 AM
