Build Log
Gee Bee Z from Fiddlersgreen for PZ gear (with short video)
Hello everybody!
I've started the building of this mythic plane from the golden age. WS: 45,5 cm or 18". Material used: mostly 4mm wall foam covered with printed waterslide decals. 2mm depron for the wing and a few inner parts. durobatics I've copied every part of the graphics in a word file at the right scale. i've then printed the parts ('Mirrored') onto the decal paper. Once the ink has dried (half an hour) i apply some UHU glue on the ink side and stick it on the foam. After a while, i I apply a cotton soaked with water on the backing paper. When the backing becomes slightly transparent, i slide it off the decal. Easy! I've started with the wings. They are covered on both sides. I've glued two light carbon spars on the leading edge. The ailerons are like the original model. I've first thought of using 2 PZ micro servos, but not only it will add some drag, but this is not very good looking. So, i would like to use a single servo with a carbon rod which runs along the wing and turns toward the aileron. I have a 1,6g falcon servo. I don't know if it has enough torque to move the ailerons as the linkage are bent and thus need more effort. A few years ago, someone has posted on this forum a video of that kind of control, but i'm unable to find it. Thanks for your advices and your help. More to follow. |
Here is the fuselage.
I like it! The graphics are awesome and I know the building method works well as it did in my Pitts that you commented on. I look forward to seeing the completion.
I am interested in your adhesive approach to the waterslide decals. Do you think a spray adhesive like the 3M 77 would work as well? |
I'll try to update the thread as soon as i can. I hope you'll start your own soon. Frank. |
That is what i like with the paper models. Great graphics without paint! Quote:
The adhesion with 3M77 is better than with UHU, whatever foam you are using. Now, i guess that The 3M77 glue is heavier than UHU, and it can be an issue on small planes. Also, i have a plane which tranparent parts on the graphics has turned to "yellow" after a while, and i wonder if it is not because of the 3M77 glue... |
Dummy engine
I've glued the mounting ring and the dummy engine to the fuselage.
These parts are made with durobatics covered will decals. I've found on internet a picture (see atachment) of the front part of the engine, which is better than the fiddlersgreen one. I'm about to finish the cowling. It will slide over the dummy engine. The engine is left open: the front part will be in the cowling (at the front behind the cowling ring) and will be used to support the real motorization. more pictures to come. |
Waterslide decals
Thanks Pete.
For those who are interested by using waterslidedecals with wallfoam, i recommend to buy to CraftyComputer in UK. The decals are glossy, very light, and work very well with the "miror printed" technic. I've tried lasertran decals. Not only they are not glossy, but the result with the "mirrored printed" technic is very disappointing. Also, i use UHU Por glue for the building. This glue is really magic. Here are pics of the cowling alone and over the engine. More to come. keep on watching. |
ailerons control
Thanks Derk!
About the ailerons, i've thought of using a very light wire for fishing with the system shown on the image. Not the easiest, but perhaps the most efficient way to move the ailerons. |
Thread Tools | |
Similar Threads | |||||
Wanted | Kyosho Gee Bee Z BellyPan/ Canopy/ Landing gear wires needed | outtacontrol | Aircraft - Fuel - Airplanes (FS/W) | 0 | Dec 15, 2010 11:08 PM |
Wanted | Kyosho Gee Bee Z | outtacontrol | Aircraft - Fuel - Airplanes (FS/W) | 2 | Nov 26, 2010 03:05 PM |
Sold | Kyosho Gee Bee Z 40 NIB | Frankensteen | Aircraft - Electric - Airplanes (FS/W) | 6 | Sep 22, 2010 08:02 AM |
Question | Gee Bee Z balsa-kit from Jamara | M-SAX | Scale Kit/Scratch Built | 8 | Feb 28, 2010 02:24 PM |
Wanted | Adrian Page Gee Bee Z 1/5th and/or Gee Bee R2 1/5th (looking for) | Xanix | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jul 23, 2007 06:16 PM |
