Hobby King Long Range FPV 168 Airplane |
First things I've noticed:
1- simple plastic canopy, can't use it for fpv (will they ever start to build cool lexan fpv usable canopies ?) 2- landing gear too weak ? 3- no side window ready 4- no flaps (this is what I really don't like) 5- maybe even more tail heavy than the skywalker? 6- no slots for pan&tilt servos ready but it looks very good anyway... ok who's first? |
What advantages does this have over the EPP FPV? Seems like a pretty comparable plane, other than it's not foam. Is fiberglass that much better? It does look more streamlined than the flying block of foam that the EPP FPV is...
I'm all for choice, and it looks more professional than the EPP FPV, just curious as to why HK would copy something when they have a similar piece already available... |
for sure the tail section is more rigid, the epp version is not rigid at all. Fiberglass is thinner so you have more space inside. It looks better, and it looks better when you paint it but it's not so easy to make holes where to put your equipment like video TX, pan&tilts, antennas...
We need to wait and see prices, weight and see if they add flaps in the final version ( I really hope so). I also love the landing gear, but it needs a better one.. that one is bent already under the weight of an empty airframe. |
also, if it needs the same weight amount for correct CG this is going to be too fast for me...
I was hoping they'd make a twin boom FPV clone instead of this. Oh well, maybe next time. Hopefully they'll get some airframes in the US as well, so shipping isn't so crazy. |
I would like to make this twin engine with counter props, mounting the engines in the center wing section... more efficiency, less CG problems, less noise...
there are also no airscoops to chill the ESC and motor
I just wonder why these people don't come here and ask what we want first... ?
it's here.. https://www.hobbyking.com/hobbyking/s...dproduct=15236
should i or shouldn't i.. like this plane.. got the epo version.. it doesn't mention any carbon stiffener at the wing..how is the wing held together..pics here shows 3pcs..at hk is one solid wing.. |
Thread Tools | |
Similar Threads | |||||
Discussion | Whale Watching BWEZ*- Long Range FPV | scrtsqrl | FPV Talk | 184 | Oct 10, 2011 09:17 PM |
Question | Long Range FPV question - (and general fpv questions) | MaximumBob | FPV Talk | 15 | Dec 08, 2010 09:07 PM |
Discussion | Best long range airplane discussion part 2 | thekubiaks | FPV Aircraft | 30 | Nov 29, 2010 10:36 AM |
Sold | RTF FPV Gear. LONG RANGE! | rcplanes1234 | Aircraft - General - Miscellaneous (FS/W) | 11 | Oct 23, 2010 09:23 AM |
