Jan 07, 2011, 09:18 AM
New Product
New ROV control System Available shortly on E-bay and rov-asia.com
In the next week there will be a new set of control boards available. I will be looking forward to any questions you might have.
Transmitter, Receiver, Light Control and Power Board with leak sensor and Alarm Circuit and two 3 Watt LEDs
Description: Name: DSC00445.jpg
Description:
Description:
This set of electronic boards includes a topside transmitter PCB, bottom side receiver PCB, light control PCB, Power distribution board for the ROV, leak sensor PCB, PVC base, Two 3 watt LED lights and topside piezo elictric sound module for giving indication of a water leak inside the ROV.
Description:
Transmitter PCB
Description:
The top side transmitter PCB is measures 45.7 mm x 89mm and is powered by 12 Volt DC 500 mA. It can control
1. 4 Thrusters. Two aft, one lateral and one vertical. Can control both DC brushless and DC brushed motors with external circuit upto 1KW motors.
2. Two servo units for Pan and Tilt functions for
camera viewing angle control.
4. Light dimmer control.
3. Leak alarm.
The inputs of the transmitter board are connected with a 10 K Ohm potentiometer or a joystick.
Receiver PCB
Description:
The receiver PCB is 33.0 mm x 35.5 mm and receives information from the transmitter PCB and then outputs a signal into R/C PWM format to control the following.
1. Four ESC units (not supplied) that are used to control
DC brushless motors.
2. Light dimmer control board used either for control of
LEDs or 2 x 12 Volt halogen 75W bulbs.
3. Two Servo units (not supplied) which control pan and tilt
unit for the control of the viewing angle of camera.
4. Leak sensor board.
The receiver only provides the PWM signal and not the power for these external Functions. The sevo functions for pan and tilt are the only two functions that can take power from the receiver.
Light Control PCB
Description:
The light control board PCB is 33.0 mm x 35.5 mm receives the PWM signal from the receiver board and can either control LEDs or two 75 Watts halogen bulbs. The light control board also has a fuse to protect the circuit.
Leak Sensor Board
Description:
The leak sensor board is a very simple board that detects a leak of water into the ROV an protects the receiver board.
The Power Disruibution and Fuse PCB
Description:
The Power distribution board distributes 12Volts DC to all the functions of the ROV and protects boards with a SMD fuse. Depending on the ESC controllers, lights used and servos used use will depent on the value of these fuses.
Discussion DSKinetic.com updated with new control throws sll914 Dynamic Soaring 0 Oct 26, 2010 11:33 PM
Off Site Radical RC Das mini-bipe for sale on e-bay fly2mike Aircraft - Electric - Airplanes (FS/W) 11 Oct 12, 2010 12:23 AM
Off Site E-bay New OS 46SF pryor808 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 06, 2010 11:08 PM
Alert New LIVE ON-LINE SUPPORT NOW AVAILABLE at MaxAmps.com JAM Product Announcements 0 Jan 04, 2008 12:43 PM
