Dec 29, 2010, 11:09 PM
Are Cee
Help!
1/12 P-51D Mustang Conversion
Hey
I am currently in the process of building the House of Balsa 1/12 P-51 D Mustang kit and am wanting to convert it to electric.
My question is what motor would be the best for this conversion or if some of the ones I already have would work.
Here are some specs on the plane:
Wing span 36 in.
Wing area 216 sq. in.
Wt. with radio 22-28 oz.
Wing loading 14.6-18.6 oz./sq. ft.
Fuselage length 28.5 in.
2-4 channel radio reqd.
Engine TD.051 - .10
I have a 2200kv motor ( http://modelaero.com/product/SM2212-6G.html ) that I thought might work with a 2 cell but still might be too much. I also have a few 1300kv and 1500kv bluewonders that I could use but not sure if those would be enough.
I have a good range of batteries and ESCs so I just need help deciding on the motor.
Any help is appreciated.
Thanks!
`Deluxe
Dec 30, 2010, 09:58 AM
Are Cee
Anyone?
Dec 30, 2010, 05:40 PM
Head NEAT geek
Tom Hunt's Avatar
I am going to be ambiguous on purpose.
Use the 1300 KV blue wonder if it is anywhere near in size to an axi 2212 motor and use a 3S 1200-1800mah pack and prop until you get to about 15 amps.
should go like stink!
Tom
Dec 30, 2010, 06:21 PM
Are Cee
I looked up the 1300kv bluewonder and it seems that its max amp draw is only around 7.5. So Im not thinking that would be enough for this plane. Would only put out like 75 watts on a 3 cell and I was thinking about having around 150watts of power.
How would a 1000kv towerpro motor work out?
Dec 30, 2010, 08:42 PM
Head NEAT geek
Tom Hunt's Avatar
sorta the same answer... since you are not providing links or specs to the motor.
Use the 1000 KV towerpro if it is anywhere near in size to an axi 2212 motor and use a 3S 1200-1800mah pack and prop until you get to about 15 amps.
Tom
ps... yes, I would shoot for 150 input watts... that's why 3S (under load, 10V) and 15a. 10 x 15 = 150.
Dec 30, 2010, 10:28 PM
69SuperBee's Avatar
Deluxe,
Try this link to much more detailed information on that TP motor:
2409-18 at Heads Up R/C
All of the motors listed there have very detailed information to help you pick what you need. Their service is great, and their shipping is a flat-rate of $2 for just about everything.
As for the HoB P-51D, I built a couple of them long, long ago. Keep it as light as possible, and shoot for at least 24 oz. of thrust.
HTH,
D
Dec 30, 2010, 11:05 PM
Are Cee
Thanks for the link. That was helpful as it was a very detailed description. Might have to order one from there since it is a lot closer.
Dec 31, 2010, 08:50 AM
Head NEAT geek
Tom Hunt's Avatar
1000kv... possibly, but I 've seen these motors and they are not well made. the shafts break or bend easily, even with prop saver adapaters.
1300 and 1500 way too small a motor.
https://www.hobbyking.com/hobbyking/s...idProduct=4908
or a little more money but here in the states:
http://www.bphobbies.com/view.asp?id...7&pid=B1488466
I have quite a few of these BP motors and they are all very good.
Tom
Dec 31, 2010, 12:44 PM
Are Cee
Tom
Alright. Thanks for all of your help.
H.O.B P-51D Mustang 1/2A conversion. genovia Scale Kit/Scratch Built 101 Aug 16, 2017 11:45 AM
Sold Top Flite P-51D Mustang - 1/5 ARF modlflr Aircraft - Fuel - Airplanes (FS/W) 10 Oct 04, 2010 12:09 AM
Discussion 1:1 Blue Lou P-51D Mustang Crashed Bonez Electric Warbirds 49 Jul 23, 2007 11:12 PM
Flying Styro P-51D Mustang r/c conversion,anyone successful? bipeflyer Parkflyers 20 Jul 29, 2001 12:54 AM
Flying Styro P-51D Mustang r/c conversion,anyone successful? bipeflyer Scale Kit/Scratch Built 0 May 16, 2001 02:35 PM
