Dec 05, 2012, 01:38 PM
GER 3788
Hey Eric,
yes of course....fits perfekt!!
And CG is easy...nose is shorther...tail is longer, no lead in the tail needed anymore.
Also space for 9s and 10s packs is much better.
Durability....I cannot really say. The first fuse I got was preseries and it feels a bit tougher that the series one...let´s see.
So everything can be exchanged between 4 and 4B
Dec 05, 2012, 04:24 PM
Highfly!'s Avatar
So I can order just the fuselage from stratair?
Dec 05, 2012, 04:38 PM
>8-)
MrMagic's Avatar
I don't think you can swap 4 and 4b without a bit of modding.
The 4 wing had a circular metal tang at the front that mates with a hole in the fuselage.
The 4b wing has a larger rectangular tang.
This tang is pretty important. I expect you could put a 4 wing into a 4b fuselage and it would work without modding but you may pull the wing bolts on a dodgy landing.
Dec 06, 2012, 02:35 AM
GER 3788
Dudes...
I just did that and its no prob!
Yes Magic, you´re right, the 4 has a pin and the 4b has a bigger centering.
The only thing to do, dremel a slot for the pin...that´s it.
I already flew that combi several times....elevator settings are the same, also the adjustment before flight. Fuse on the table and 126mm from the bottom to elevator edge.
Dec 07, 2012, 02:15 AM
epwierman's Avatar
Thanks guys,
Very helpful.
A local kid, 13 yrs old, was watching some practice. I'd seen he could fly his models well, so I handed him my transmitter. The rest was history. He is hooked on F5B and likely going to be Rainer's next top pilot. :-)
He ended up with my RW's, did some practice in SD, did mid 35's his first day out. Needless to say, he won the support of all the locals.
Flying the shizen out the the rw4's, he eventually had a bad landing in tall grass and now needs a new fuse.
Glad to hear the B will fit the bill.
Ciao,
Eric
Dec 08, 2012, 03:37 AM
We have a video concerning compatibility RW4 - RW4b on STRATAIR facebook.
Brgds,
Rainer Stratberger
Build Log Build Thread - Pixie 20" Symmetrical Electric Flying EPP Wing Blue Note Flying Wings 28 Nov 10, 2011 10:32 PM
Rave Official GAUI 330X-S Build Thread/ Tips & Tricks EmpireHobby Tech Multirotor Drone Talk 183 May 19, 2011 11:19 AM
Discussion Custom Build Trailer Build Thread Trent Collins Australia 20 Sep 29, 2010 03:40 AM
Discussion GWS P-40 Not a Build Thread Thread TopSpin Vendor Talk 11 Sep 20, 2010 05:40 AM
Build Log Build Thread or not to Build Thread? - Redback malachite Slope Soaring 35 Feb 28, 2006 01:12 AM
