PL8 and power supply - RC Groups
Dec 21, 2010, 01:33 AM
MrJayd
Will the PL8 work with a iCharger P350 Power Supply? From what I am reading I know the PL8 needs a lot of power to it but can this work as a start? I still can't figure out all these calculations.... :-)
Or maybe this PS is better suited for the Cellpro 10s charger?
Thanks.....
Dec 21, 2010, 03:54 AM
Just have look at FMA website for detailed information for power supply etc.
Dec 21, 2010, 04:30 AM
Yes - The PL8 will work fine with the P350 power supply with the following caveat:
The PL8 will be limited in its output power delivery due to the current and voltage capability limits imposed by the power supply.
It is relatively easy to work out the actual calculations by utilising the following Excel spreadsheet. Just plug in the values and the spreadsheet does all the hard work for you...!
Cellpro PowerLab 8 Power Calculator
Dec 21, 2010, 08:36 AM
President, FMA, Inc.
Tim Marks's Avatar
Thanks.....
Hi:
Be sure to set the input supply limit on the PL8 so that it does not attempt to draw more current than the PSU is capable of delivering. We start to address this early on in the manual because we feel it is very important.
Also, the link to the spreadsheet provided by Costas did not work for me. Here it is again:
http://www.revolectrix.com/support_docs/item_1301.zip
Tim Marks
Dec 23, 2010, 12:19 AM
I have the P350 power supply and using it with the PL8. I'm not charging at high rates, maybe 6A at the most right now, but it works just fine.
Feb 08, 2018, 06:59 AM
QUAD4EVER's Avatar
(edit - wrong thread)
Question Hp DPS 800gb a power supply Nocept1 Batteries and Chargers 320 Jun 24, 2018 08:57 PM
Alert Power Supply with FREE Power Bus - *SPECIAL* CSRC Tech Crew Batteries and Chargers 0 Sep 28, 2010 11:08 AM
Discussion Wrong Power Supply, Can I still Use It? jlcamp7 Batteries and Chargers 11 Sep 03, 2010 11:31 AM
For Sale New CellPro 10S + Almost New AC/DC Power Supply + New 2S 3200mAh Lipo DKNguyen Aircraft - Electric - Batteries & Chargers (FS/W) 5 Sep 01, 2010 04:20 PM
