Dec 17, 2010, 06:18 AM
Need Help Hovercraft project.
My 14 yeard old and I are trying to desing and build an electric RC hovercraft.
We would appreciate any information and avice you may offer.
One of the question I have is what motor and prop and battery to use.
I think it would be smart to desing the craft arround the power system.
The hovercraft would be a single motor design for lift and thrust.
I was thinking of using a 6-3 prop with a 2000-2200KV brushless motor.
will that provide eough power to lift a 20"x 12" "D" shape platform (and electronics) made out of foam reinforced with thin plywood or balsa?
My other question is how nest route the airflow from the intake scoop behid the bottom of the propeller arc to create the lift? We are thinking of using simular system to this:
RC Hoververcraft design,build and test runs 2nd video - road and snow (3 min 16 sec)
I would appreciate any suggestion.
Aaron
Dec 20, 2010, 01:39 PM
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
How many grams is that motor? Thats a pretty small hovercraft so as long as it is a around 20 grams it should get the job done.
Use Basswood, its stiff and not as heavy as Plywood.
Dec 20, 2010, 07:24 PM
Just a bored guy
boredom.is.me's Avatar
You wouldn't even have to reinforce it if you use the right thickness or type of foam. I plan on doing a 9' long ridable hovercraft out of foam.
Dec 21, 2010, 03:45 PM
Thanks for the replies. I appreciate the advice.
I guess the key is to keep it light
Dec 21, 2010, 03:48 PM
I was thinking of using a motor that weights 40grams. Is a 2200Kv 20A with a 6-3 Prop.
Dec 21, 2010, 11:00 PM
Just a bored guy
Is it an inruuner or outrunner? What is its dimensions? How many cells and what type will you be running? 40 grams is a lot of motor for a craft this size.
Dec 23, 2010, 01:25 PM
This are the specs of the motor I want to use:
Ni-Mh Battery:8 - 10 cells
Li-Po Battery: 2 / 3 cells
RPM per volt : 2200
Poles: 14
No Load Current / 10V: 2.05A
Max Current: 30A/60 sec
Dimension: 27.5x26
Shaft: 3.17mm
Weight: 34g
Recommended Max Propeller: 6x4
Recommended Model Weight: 200 - 500g (7oz to 22oz)
I was thinking of a 3 cell 1500ah battery and a 6-4 prop.
Dec 23, 2010, 01:28 PM
I think is an outrunner.
Here is the link:
http://www.graysonhobby.com/catalog/...jet-p-765.html
Thanks for the help.
Dec 26, 2010, 11:58 AM
airbagit13's Avatar
You should be fine with that greyson combo, if you find that you need to loose some weight you can always just put on a 800 mah 3s lipo to lighten it up.
Dec 26, 2010, 12:31 PM
Just a bored guy
What kind of skirt will use?
What type of terrain will you use it on?
Dec 26, 2010, 01:28 PM
Just a bored guy
This is an incredibly fun craft. It only takes a few minutes to cut and build.
http://174.130.107.184:9997/plans/Bob_the_hoover.pdf
Dec 26, 2010, 06:17 PM
airbagit13's Avatar
That link is not working, can you please send me the PDF, I would like to check it out.
chad@executiveprinters.com
Thanks.
Dec 27, 2010, 01:13 AM
Just a bored guy
Here you go.
Discussion Scratchbuild Hovercraft need help airbagit13 RC Hovercraft 5 Nov 05, 2010 03:14 PM
Hovercraft design - need help maciek Electric Plane Talk 16 Dec 09, 2006 05:46 AM
Build Log Scratch-Built Huge Hovercraft Project. Oh, and it has Rockets & Parachutes dgfisher2004 Car Talk 0 Jan 06, 2006 01:17 AM
Mini Hovercraft need help with BRUSHLESS&Li-Po mod Paul Fadis Electric Power Cars 0 Jan 23, 2005 03:35 AM
Hovercraft project cdw3423 The Builders Workshop 2 Dec 02, 2004 07:03 PM
