Dec 16, 2010, 06:44 PM
Hitec/Multiplex USA
MikeMayberry's Avatar
New Hitec Optima 6 LITE
Introducing the Optima 6 LITE w/battery telemetry.
Weight: 8.5g (Revised... sorry 7g is without the BODA.)
Available early Jan '11.
Mike.
Dec 16, 2010, 06:52 PM
Buzzkill2's Avatar
Sweet! 8.5g with batt. telemetry. Nice!
Dec 16, 2010, 07:16 PM
Is it full range or park-flyer?
chewy
Dec 16, 2010, 07:54 PM
AMA # L576
vhoward1122's Avatar
The Optimas are full range. All they've done is take it out of the hard plastic case, trim it down as much as they could and put shrink wrap on it.
Dec 16, 2010, 08:33 PM
Tom the Tinkerer
Twinck's Avatar
The all important question... Price?, bulk deals?
Tom
Dec 16, 2010, 08:40 PM
So is this functionally the same as optima 6, just light?
For park-flyers, should I use this one or Minima?
Dec 16, 2010, 08:45 PM
T3beatz's Avatar
Ok, now the 4ch next??
Dec 16, 2010, 09:08 PM
i want a 4 ch, for my dlg, and an airspeed sensor so I can program a buzzer for stall speed.. build that hitec!!!!!!!!!!!!!!
Dec 16, 2010, 09:10 PM
as much as I can
beenflying's Avatar
Fantastic!!! Thanks Hitec!
1/ Is it just the case that's different?
2/ How do the dimensions compare to the standard Optima 6?
3/ What aerial does it have?
Dec 16, 2010, 09:15 PM
Not your average DiggsyBear
Diggs's Avatar
Nice!!! So can I be lazy and ask what is the difference in weight from the stock to the lite version? And can we get some Hitec confirmation that this does have battery voltage telemetry? I will certainly have to test a few.
Thanks Mike!!
Diggs
DOH, I read that a bit too quickly. I see Mike states in his post that it has Battery Telemetry.... DOH!! And I looked up the spec from Tower hobby on the Stock optima 6 15 grams vs 7 grams on the Lite!! Sexy!
Dec 16, 2010, 09:20 PM
Sweet!!!
Is it going to be the same price as the regular optima 6?
Dec 17, 2010, 12:24 AM
Hitec/Multiplex USA
Essentially this is exactly correct, but it's a laminated paper case, not shrinkwrap. It still uses the BODA so you can fly it in anything.
It's only going to be available as a single item for now in USA market but may be available in 3-packs and outside the USA in the near future if the demand is high enough. While the Minima will still be slightly lighter (when it's available) with the case (1g) and without the case (3g,) the advantage to the O6 LITE will be the battery telemetry... not to mention available shortly.
Pricing is $49.99.
Mike.
Dec 17, 2010, 01:48 AM
More Combat Please!
Wind_of_Change's Avatar
Ooooo. Droool. So cool that it still has battery telemetry & SPC.
Way to go Hitec!
Dec 17, 2010, 08:04 AM
please send them to the uk please!!!
Dec 17, 2010, 08:43 AM
I would say it would be sufficient to send it to Germany at least ;-)
For Sale Hitec Optic 6 with 2.4Ghz TX module, 72Mhz module and Optima 7 2.4Ghz RX $160 ! Sky_Dancer Aircraft - General - Radio Equipment (FS/W) 2 Dec 18, 2010 09:51 AM
Sold Hitec Optima 6 RX $35 shipped cjdscratch Aircraft - General - Radio Equipment (FS/W) 4 Dec 06, 2010 09:15 PM
Wanted Trade Hitec Optima 7 RX + $ for a Hitec Optima 9 RX cjdscratch Aircraft - General - Radio Equipment (FS/W) 0 Dec 01, 2010 10:45 PM
Wanted Hitec optima 6 JBAZ4 Aircraft - General - Radio Equipment (FS/W) 0 Nov 14, 2010 06:21 PM
Wanted Hitec Optima 6/7 RXs (2.4GHZ) JBAZ4 Aircraft - General - Radio Equipment (FS/W) 3 Nov 12, 2010 03:34 PM
