Dec 03, 2010, 02:22 AM
Paul Kohlmann
Longhorne's Avatar
Build Log
30" Messerschmitt Me 109--early
Midway through our B25 build I got the itch to work up the next fighter in my lineup. I've always had a soft spot for the early 109's with their cleaner lines and squared off wings. It seems like there are tons of G's available in the kit market, but not to many of these early birds with the exception of the smaller Guillows kit. I've got alot of respect for the battle-hardened Gustavs but all those bulges just detract from the beauty underlying airframe for me. If that raises your ire, I'll politely point out that Adolf Galland felt pretty much the same.
After studying all the variants between A and Emil, I figured I could cover them all with one framework and two sets of chin and wing scoops. The general construction will be very similar to the Wildcat and the Ki84--stick and tissue type with a load of stringers and an AUW of ~8oz.
Here's a few shots to kick the thing off.
Paul
Dec 03, 2010, 05:30 AM
bosley's Avatar
Sweeeeeeeet. :d
Dec 03, 2010, 05:56 AM
It flew once before...
jofrost's Avatar
I like !!!
Dec 03, 2010, 09:50 AM
Pile-it
Alien_Tech's Avatar
Looking forward to this one Paul!
Dec 03, 2010, 10:10 AM
Prowler901's Avatar
Holy Smokes!!! Do you ever take a break?!
This should be fun
Todd
Dec 03, 2010, 10:33 PM
Still the "Pro"-crastinator...
Steve85's Avatar
Paul,
Bring it on!
Steve
Dec 04, 2010, 12:56 AM
Paul Kohlmann
Longhorne's Avatar
Bosley lives! I've heard a rumor that you're going to follow this one up with a FW 190, right?
Todd--this is a break! Actually, Drew started to burn out on the B25 a few weeks ago. I figured out that leaning on him too hard would spoil the whole thing. Alternatively, getting a side project here smoothed things out alot. He's back on track now, though, so this one will proceed but its in the #2 spot for a little while.
So here are the solid models that I'll be working from. Again, the plan is to go with a common framework with two scoop sets.
Paul
Dec 04, 2010, 01:08 AM
Prowler901's Avatar
Well, then take a break anytime you want I like the models that you've chosen.
Todd
Dec 04, 2010, 07:38 AM
bosley's Avatar
Yeah Paul I am still around.
I have the FW-190 coming along at a snails pace. Wing and tail feathers are done but I have been stalled out on the fuse. I am trying to get a solid of the fuse that I can use to slice up but I have been struggling to do so in Rhino. It certainly isn't teh programs fault, it is that I have not sat down and forced my self to learn the in's and out's of the thing yet.
I need to just buckle down and go for it as drawn, it has worked out in the past. But my goal with the 190 was to leasrn how to get the solid drawing first and then slice it up as needed.
At any rate the 25 and your 109 are looking top notch. I was a scared off of the 109 a little bit after seeing how tight the nose was on my Zero. The nose on the 109 is pretty skinny but it is a lot longer than the Zero. I will have to get on of these as well!!!
I will be watching intently, and trying to pick up what I can of you CAD work!!!
Jeff
Dec 04, 2010, 10:41 AM
Steve85's Avatar
Paul,
Interestingly enough, the Guillow's 400 series kit is much closer to an A-D model than it is to an Emil. The palstic cowl definitely has the deep D model radiator, and the plan lacks any reference to wing-mounted rads. When I built mine, I built a new cowl to convert the Guillow's to an Emil.
Where did you find those fantastic 3-views? I'm committed to building a Hurricane for Funbuild 4, and would like to find a similar set to get the formers right.
Steve
Dec 04, 2010, 02:45 PM
D-Rock's Avatar
Great googly moogly Paul, you are cranking these out on a nearly monthly rate! Looking forward to seeing more. BTW what CAD program are you using?
D-Rock
Dec 05, 2010, 12:51 AM
Paul Kohlmann
Longhorne's Avatar
Jeff, you're right that the nose looks tight, but I sure like that length. This one should be really easy to balance. I haven't used Rhino, but I feel your pain on the fuse. I spend alot more time on it than the rest of the project combined by a fair margin.
Heya Steve! This is a pretty good site but be careful--you may end up with 8 more projects before you know it: http://www.airwar.ru/other/drawe.html
and in particular: http://www.airwar.ru/other/draw2/hurr_aik.html
D-Rock--I'm using SolidWorks. That one-a-month thing might be a little generous, though!
Well, here's some screenshots of how the design comes together.
Paul
Dec 05, 2010, 10:59 AM
shotibf109's Avatar
Exelent idea!! I tuned in!!!
Dec 06, 2010, 01:39 AM
Paul Kohlmann
Longhorne's Avatar
Thanks for that! I've been watching your Gustav. Nice work!
Here's the overall layout. Regarding spaciousness of the front end, I don't think that it will be that bad. The plan is to vac form the very front of the cowl and back this with a simple framework so that it can be removed. With the cowl and the battery hatch out of the way there should be plenty of access to the motor and such.
Paul
Dec 06, 2010, 05:57 AM
jofrost's Avatar
Hi Paul ,
That is about the location of my battery for my old Bf109 . Looks as you enlarged the tail a bit ? ( which is good )
Discussion New 2009 Super Scale 4 CH Messerschmitt ME-109 Questions ToraToraTora Vendor Talk 4 Feb 01, 2016 12:31 PM
For Sale SIG Messerschmitt bf 109 RxR ARTF Never Flown bobschultz Aircraft - Electric - Airplanes (FS/W) 2 Oct 26, 2010 01:55 AM
Discussion The New 2009 Scale 4 CH Messerschmitt ME-109 kvitekp Vendor Talk 2 May 03, 2009 08:38 PM
Discussion Scratchbuilt Messerschmitt Me 109 Z B17G Yankee-Lady Electric Warbirds 12 May 06, 2007 12:59 PM
Sold FS: FSK Flying Styro Me-109 (Bf-109) $30 shipped shschon Aircraft - Electric - Airplanes (FS/W) 4 Jun 14, 2005 03:27 AM
