Nov 27, 2010, 05:59 AM
FXG
FXG
How To Make Futaba Big 6 Pin Cord Work With Reflex Simulator
Hi,
I have Futaba T6XHs radio and is working fine with sim cord with usb dongle on FMS sim but Reflex XTR is not detecting it, can anyone help me find the solution?
What is the pinout for Reflex sim, I can manage to change the connections.
Thanks.
Nov 27, 2010, 08:00 AM
Relflex needs its own proprietary interface (dongle) to work. You know, the interface that comes with Reflex when you buy it. You can't just use the Reflex software with any old USB interface.
Steve
Nov 27, 2010, 09:57 AM
Originally Posted by FXG
......but Reflex XTR is not detecting it, can anyone help me find the solution?
The solution is to buy a retail copy of XTR. This will, as Steve pointed out, come with the proprietary interface needed for XTR to function
Nov 27, 2010, 04:43 PM
FXG
FXG
Hi,
Thanks to everyone who replied, coming back to the original question:
What is the pinout for Reflex sim?
Thanks.
Nov 27, 2010, 05:42 PM
Hi,
Thanks.
So getting back to the original reply... do you have the genuine Reflex dongle ?
You just cant grasp it... in order for any interface to work it needs to receive the PPM signal from the TX. If a cheap USB interface that emulates a windows joystick in control panel works with FMS then it's obviously receiving the PPM signal from the TX (most pin outs are well documented on the net) so the same pin on your TX must be used in both cases
The FACT that it doesn't work with XTR is that the XTR dongle (interface) amongst other things encrypts the packet data that gets sent to the PC. The software then receives this encrypted data and deciphers it. It's this data encryption and handshaking that forms the copy protection for the software. Now unless you are cleaver enough to work out that encryption, and can then re-program the PIC micro that forms the hart of the interface using your bog standard interface WONT WORK with XTR !
The other factor is that this is trying to circumvent the copy protection of the product and whilst it is in breach of the rules and you risk getting warnings, it is also illegal.
Nov 28, 2010, 03:48 AM
To answer your question directly, the Reflex interface is terminated with a jack and the Reflex "pinout" is tip = signal, outer = ground.
Not sure how much that helps you, but now you know .
Steve
Help! Please Help In Pin Simulator Cord Socket Replacement FXG DIY Electronics 14 Nov 27, 2010 05:49 AM
Discussion X-Plane Simulator with Reflex XRT cable davemcp Simulators 1 Nov 23, 2010 10:53 AM
For Sale Reflex XTR simulator with Futaba square & round plug Chad1979 Aircraft - General - Miscellaneous (FS/W) 0 Nov 20, 2010 02:24 PM
For Sale Reflex XTR simulator w/ Futaba square & round plug Chad1979 Aircraft - General - Miscellaneous (FS/W) 3 Oct 24, 2010 10:43 AM
For Sale Reflex XTR simulator w/ Futaba square & round plug Chad1979 Aircraft - General - Miscellaneous (FS/W) 4 Oct 12, 2010 04:42 PM
