I just ordered my Radian Pro! I can't wait to try her.
A while ago i asked here if 2200 batteries would do, and they would. But i wonder wich battery is the goldspot between floating and duration? As i can think the 2200's are so heavy that she will loose altitude faster then a smaller battery? Edit: Very nice video Brookfreeman |
Very nice video and nice flying. That landing was super smooooooooth! Thanks for sharing it with us. Bill in MO |
Thanks Coenraad, and Bill for your comments! The Radian Pro makes an awesome camera platform. I can't wait to get her in some lift while I am filming.
I'll use the 2200 if I feel more like motoring around for a while, or if there is a strong wind. The extra weight seems to help the RP penetrate into the wind a bit better. I'll use the 1300 if I have good lift conditions, and need few or no motor runs. There is plenty of juice for 1+ hour of flight when you're not running the motor much. I once had a 61 minute slope flight with perhaps 6-8 short motor burns of about 5 seconds each, with the 2200 pack. I was still pretty new to the plane, so I was stunned to find that I only had to put ~780 mAh back into the pack. At that rate, I could have easily flown for well over 2 hours! |
Reason: Spelling
Thanks for the inputQuote:
Thanks for your reply's I think I have enough info to get it programed. Phil |
Just came on and noticed your comment. Mine looked the same as yours (and as others have experienced). I inserted/wedged small strips of some scrap 1/64" plywood that I had on hand, between the stab and mounting platform. Added them to underside side (side that was low), and then to the opposite, upper side that was high (i.e. tilted up). Everything is a little tight but now everything is lined up.
Thanks for the comment! I am using the GoPro Hero 960; much like the GoPro Hero HD, but will not shoot on 1080p or 720p 60 frames per second. I shot my vid in 720p @ 30 fps. To mount my camera, I took a standard GoPro flat mount, and removed the double sided tape. I measured the CG with an 1800; temporarily attached the camera and mount to the plane (with a small piece of double sided tape) to measure where the camera should go, as not to affect the CG (but it will cause some drag). I traced the shape of the mount on the fuse then carefully scored the line with my knife and pieced out the foam. I applied a thick layer of Gorilla Glue 2X white on the mount, and then dampened the fuse where I would place the mount. Hope this helps! Brook |
broken wing tab
I posted my version of a fix somewhere near your original fix post but I think it's worth repeating (although I guess it doesn't help you because of your total mod ... but when one tab broke on me, I removed the insert halves from the fuse completely, pressed the good tab into a 2 inch block of clay until it was flush with the clay block surface. then I pulled it out and laid the broken tab (they seem to break right at the screw hole, ) into the impression left by the good tab. This leaves a perfect 'well' impression of the missing tab tip. I then poured a speck of quick setting liquid epoxy into the missing tip impression and also allowed the epoxy to glaze over the intact part of the tab. The result is a perfectly formed tab that is overall a tad thicker, super strong, and accepts the screw length with no problems ... In fact, I do not think this tab can be easily broken by hand, not at least with the syringe epoxy I used.
Saw one fly a couple of weeks ago and just had to add it to get one.
When at the hobby shop was confused by the ARF, BNF, PNP and RTF versions ?? The hobby shop owner turned me on to the **IAGAMSAESCBYUYORAL version. **It's already got a motor, servos and ESC but you use your own radio and lipo version. Joe M. |
Had my 7th flight today but the wind was blowing too hard for me here in Southern California. At full throttle had just enough power to fly forward back to my launch site. Landed after 6mins getting tossed around in the sky, but the approach to landing was a piece of cake! So much wind over the wings providing lift I landed with the plane at a stand still!! Added flaps for fun and she floated wings level right at me feet. |
The stock tab is not a great design... When plastic has to flow around a pin to create a through-hole in a mold, it forms a "knit line" or "weld line" where the flow meets up again on the other side of the mold pin. This will always be a weak point in the plastic. No avoiding it, unless the hole is later drilled as a second op.
To compound the problem, the designer then added a countersink for a flat head screw. Thin plastic hates countersunk screws. The taper of the screw will place increasing stress on the perimeter of the hole as it is tightened. Add that to a weld line, and you're just asking for trouble. I'm keeping an eye on my tabs after every landing. I feel it's just a matter if time before the inevitable crack at the hole. Maybe I'll get some crummy no-fly weather before then so I can have an excuse to do my planned magnet mod! |
I got one of these a few weeks ago, and on the maiden (unmodified) the right aileron servo pooped out in a way that also caused the left one to stop responding (I had them on the supplied y-harness). I was giving aileron input when this happened, so there wasn't much hope of recovery and the model hit the ground pretty hard. Fuse was broken into 3 pieces.
I called horizon support and they agreed to send me a new fuse and a servo, and additionally threw in the qualifier that "this is a one-time thing, we can't be responsible for flight damage". This kind of pissed me off but whatever, I figured at least I was going to get the fuse replaced and have a more-or-less like-new plane, which I figured they owed me given that the one I paid $whatever for was defective from the factory. Parts arrived yesterday. Replacement servo has a long wire, but not long enough to reach the wing root. For a model that was supposed to be "ready to fly in the time it takes to charge the battery" (I think that's a more or less direct quote) I'm pretty disappointed. I'm going to replace all the servos (since I have to reinstall all but one anyway) with ones I don't think are going to fail in 10 minutes, and I expect to enjoy the model again, but dang, is this an outlier or has anyone else had an experience like this? |
Thread Tools | |
Similar Threads | |||||
Rave | New Parkzone Radian Pro-discussion thread!!! | lightspeeddud | Electric Sailplanes | 3897 | Jan 05, 2021 05:09 PM |
Gallery | Parkzone Radian Pro Video | bakon | Electric Sailplanes | 9 | Sep 30, 2015 04:20 PM |
Discussion | Official Radian Pro Thread | Magnumb | Parkflyers | 15 | Aug 16, 2015 06:12 PM |
New Product | Parkzone Radian Pro | bakon | Electric Plane Talk | 24 | Oct 01, 2010 01:39 AM |
Discussion | Parkzone Radian Pro $229.99 BnF preorder | Tekwip | Hot Online Deals | 10 | Sep 29, 2010 04:35 PM |
