With all this talk about motors cooking firewalls etc. I have this motor on my shelf, (not from a previously enjoyed plane). Would this work as a replacement to the stock cooker ?
https://www.hobbyking.com/hobbyking/s...dproduct=14397 |
Theres not screw holes where the shaft come out of the bell... So...No it wont fit... Unless you can reverse the shaft.... .. |
Hi skyhawk Newbie,
It's easy to reverse the shaft on these motors. I might have to wait till I get the plane to see what's going on. My grandmother's father came from County Cork. I've never been there, but looking at your on board camera it looks beautiful. I'll keep reading the thread. It's starting to get cold around here so basically flying is done till I go to Florida for Jan. & Feb. Pat |
think that motor can take a 11" prop Yep..it's very green over here...Skip the first 3min's untill take off...Flying over North Cork , Fermoy area...
Cann't beat Florida...My Father lives in West Palm Beach . . .. |
A few of you who enjoyed my post featuring some great FPV flying but for those who still need a more immersive experience how about this.
I don't think that my c of g would remain stable and would quickly move to tail heavy as I my pants The laundry bill would be high as well Andy |
I think Paragliding is a buzz , but that looks wicked . |
I've got a little puddle under me, and all I was doing was watching it on YouTube He must have a significant amount of "control" authority to even contemplate contemplating something that risky, but even so... The CF helmet was a nice touch. Be a shame to pulverise an expensive bit of kit like that into its constituent fibres. |
guys.. what is the best motor from hobbyking that can be used on this glider..? im looking for somthing powerfull enough to pull the glider vertical .
also how do you guys paint the bottom of the glider? i really need to add color to it as its almost impossible to see in the sky. thanks |
If you take alittle time you'll see what motor /ESC / UBEC most of us are using and what prop works best as well.... 2836 1000kv motor 40 amp ESC 5amp UBEC 9x6 prop HXT 900 Servo's 3c / 2200mAh Li-Po . |
thanks skyhawk newbie
but its a 64 pages thread.. which is way too much for me.. i actaully did read around 20 pages thou.. anyways.. i have 2 more questions.. 1- how do you guys paint the wings ? 2- the stock propeller adaptor is 3mm.. and the 2836 motor shaft is 4mm.. is it going to fit ? thnaks again |
I used water based poster paint ( Art shop/store ) if your in the states theres H2O spray paint... no the stock spinner will not fit,, You'll have to get a 45x4mm alloy spinner ( HK ) https://www.hobbyking.com/hobbyking/s...idproduct=5565 The 2836 1000kv motor is rated at 300watts , so you have to keep it under that, best use a 9x6, but Hobbyking don't sell 9x6 , do sell 9x5 props.. https://www.hobbyking.com/hobbyking/s...idProduct=7982 .. |
so a 10x6 prop will damage the motor ? both links youve sent me are out of stock.. will this work instead? https://www.hobbyking.com/hobbyking/s...m_Adapter.html https://www.hobbyking.com/hobbyking/s...ropeller_.html |
The 10x6 prop WILL burn your motor out as the watts will be over 300w.. . |
I was searching through this topic, but I haven't found the answer to my questions. Is there a possibility to simply fit 2.6m wings from Phoenix Evolution to the fuse & the rest of the Phoenix 2000 EPO? I own Phoenix 2000 from HK and I really love this glider, I have flown it alot last summer, it thermals great with my setup (stock engine & prop, 40A Turnigy Sentry ESC, 3S 2300mAh LiFe A123) but has one drawback - after some time when you get used to flying it 2m is becoming quite small (you want to fly higher, but the visibility of the model makes you quite nervous during good thermal weather). I came across Evolution version which is 2,6m and thought that it would be great if I could simply use the wings from the bigger version. So my questions are simple - will it fit to the fuse of 2m version, and if it will, than where can I buy wings alone without the rest of the kit?
Thread Tools | |
Similar Threads | |||||
Discussion | Ohhh noo, 2nd flight on the HobbyKing Phoenix 2000 | KillerCut | Electric Sailplanes | 24 | Oct 28, 2020 02:43 PM |
Discussion | Still having electric problems with my hobbyking Phoenix 2000, Crashvideo | kyrkbymannen | Electric Sailplanes | 4 | Oct 28, 2020 02:37 PM |
For Sale | HK Phoenix 2000 glider | blk822 | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 23, 2011 07:21 PM |
Discussion | hobby king Phoenix 2000 EPO Composite R/C Glider | doomracing | Electric Sailplanes | 3 | May 31, 2011 10:09 PM |
