Nov 12, 2010, 09:45 AM
Yeah Baby
bignose13's Avatar
Help!
Piano DVR Problem
I have a Piano dvr but have problems with the unit pulsing whrn recording through my Groundstation
I have a small video here but dont know what vimeo have done to the qualitynot like that on my unit or computer so have included another video from anothe member on here
It records fine from the tv so at a bit of a loss to this one
My video
Bingo17's video
http://www.youtube.com/watch?v=Fzs-A...ature=youtu.be
Simon
Nov 12, 2010, 03:15 PM
fransbr's Avatar
Hi Simon and all who can help,
I have exactly the same problems, pulsating red stripes.
I have two different HD recorders, piano recorder and a SoSpeaky mmade by Dane-Elec.
Both recorders cause problems but not on all cameras!!??
The HobbyCity pal-camera and the Panasonic GP-CX161 camera give a nice stable picture!
The FH-20C Mini CMOS 420tvl and the FH-25HD 550tvl cause problems! The pulsating red stripes also show up on my TV-screen when I put the signal through to my TV.
The cameras are good, they cause no problem when I connect my video- glasses or TV directly.
Other people should also have (had) the same problems but how can we solve it.
I feel a feeling that the solution should not be so hard, sometimes the recording starts good but after 5 seconds, the picture starts blinking.
Is there an expert who can help?
-maybe Sander knows the answer? -
Nov 12, 2010, 05:30 PM
It might be your OSD. I had all kinds of glitching and shaking in my recordings even though the video was clear in the goggles while I was flying (CX-161 camera, EagleTree OSD, V-Mate and Canon ZR-60 recording) but then I switched to ezOSD and my recordings are crystal clear now on both recorders.
I have no explanation for what caused it, but I'm really happy it works right finally.
Nov 14, 2010, 03:48 PM
Yeah Baby
bignose13's Avatar
Anybody
Simon
Nov 14, 2010, 05:13 PM
fransbr's Avatar
recorder problem
who knows a solution?
AgentCow007, thanks for you'r imput.
No it is not the OSD.
If I connect the camera directly to the recorder it gives pulsating red stripes video. In the plane with OSD and video transmitter it is exactly the same.
Sander? can you help?
frans
Nov 14, 2010, 07:06 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Invite "workshop" to this thread - maybe he can help.
Nov 16, 2010, 10:35 PM
So you have narrowed it down to the recorder does not like the camera. You have eliminated the OSD and FPV link. That is good.
It is very regular and that is strange. Is there anything in either the camera or the recorder that blinks at that rate? Is there a motion detection feature in the camera that could be turned off? A day/night that could be set to color instead of auto? Does this happen only in bright light? Perhaps you need a filter on your camera lens?
Are there any home made cables that might be connected incorrectly? Is it possible that something is shorting out the camera in some way?
Is all of your stuff PAL at 25 FPS or is some of it doing something strange like converting to 30FPS on the fly. I presume that your TV is PAL as well as your cameras and recorder... I am not a PAL expert, but I understand that there are many different flavors of PAL. I wonder if that is the issue.
Mix and match everything that can be connected. You say that the recorder works with the TV. Does the TV display the live camera image correctly?
Add more hardware to the test. Try it on a friend's TV or recorder or camera, etc.
When it is good, the colors look perfect, but when it is bad the colors are off and even the OSD text is affected.
It looks like the phase of the color burst gets suddenly reversed twice a second, but I have no idea why that would be.
I only have a few other things you might try, starting from just the camera and recorder:
- Make sure that all transmitters in the test area are switched off
- Try powering it from a battery (not an SBEC), minimum voltage and maximum voltage
- Take the camera out of it's case and wiggle things while recording.
- Try tweaking any setting that is tweakable that might change something (camera and recorder).
- Try attenuating the video signal from the camera by connecting a 75 ohm resistor from video (yellow) to ground (black). Try a 37.5 ohm resistor (two 75's in parallel).
- It may be possible to get some sort of box with video in and video out (like your TV or some other recorder) that can massage the video before you record it. If you could convert it to SVideo before recording, that might help.
Cliff
Nov 17, 2010, 01:00 AM
Yeah Baby
bignose13's Avatar
Cliff
Thanks for that Cliff
I basically have tried everything, from going from my BWEZ* with a 480 osc cam from BEVRC and the ceosd to my Twinstar with the Security2000 cam and Blackstork osd and also using my Tri with just the 540 osd board cam,
I however suspect that the only thing the crafts have in common is 2.4 tx
I am going to send mine across to Shikra as he has 1.3 on his Tricopter so hoping he will come back with some good results for me.
I have tried using different power supplies to no avail, also recording in NTFS instead of PAL, no better, also tried different cables like you said but still have the same issues.
Just hoping Shikra has good results with it on the 1.3 tx
Regards
Simon
Nov 17, 2010, 11:08 PM
cliffkot's Avatar
Piano DVR Problems
Have you checked all your video levels? My experience with some of this consumer stuff is that video and chroma levels are all over the place.
If you don't have a scope to do an actual measurement, try terminating the video with a 75 ohm resistor to drop the level to see if something changes.
It might give you a clue.
Cliff K.
Nov 19, 2010, 08:07 PM
Sna
Sna
i have the same problem here
hope a solution can be found
Nov 28, 2010, 02:49 PM
Hi All, have a some trouble with blinking colors at Piano HDD recorder (first (top left)) on picture in message #2. As I try - no way to fix it I wrote manufactured (about FM update to fix it - he answer - "no FW update can fix it").
I cant find datasheet on main video CPU inside (no public access) - and I no hope to fix and use it. If anybody find solution - many people say "Big Thank`s", I can`t find it. I try different cameras and connect it w/o OSD, RX/TX - same result
At one time I think to find the problem - i solder capacitor (0.022) between video wire and ground - will many better! But after some time - problem returning.
It NOT a OSD TX/RX or else problem - connecting camera at recorder - and You can see it.
It NOT a level - I specially buy video booster and changing video level at min to max - no help.
When I connect PIANO to PAL video out my comp - show excellent on PAL - then problem in incompatible THIS recorder and all camera PAL (Sony) at a try.
So sad
Sorry of my English.
Nov 28, 2010, 04:22 PM
bingo17's Avatar
Yeah, it is definitely something with the way the recorder deals with the colour system format.
I have a kt&c HX181H PAL and NTSC cam and the NTSC is perfect where as the PAL does the above.
Non kt$c PAL cam's appear to be fine though...
Cut your losses and get NTSC cam's, it is worth it as the recorder quality is brilliant!
So sad
Nov 28, 2010, 04:24 PM
Yeah Baby
bignose13's Avatar
Hey Bingo
Does it record through static ??
Simon
Nov 28, 2010, 04:35 PM
bingo17's Avatar
It does to a point, then it pauses and resumes as soon as video is back.
I will post a recording of static.
Originally Posted by bignose13
Hey Bingo
Simon
Nov 28, 2010, 05:22 PM
Yeah Baby
bignose13's Avatar
Cheers mate
Simon
Discussion Piano HDD-DVR Gundy FPV Talk 21 Oct 02, 2012 05:50 AM
Help! Piano DVR Help Needed (it may have crapped itself) Craig9080 FPV Talk 7 Feb 04, 2011 11:10 AM
Question What happened to the Piano DVR? workshop FPV Talk 5 Oct 24, 2010 12:52 PM
For Sale FPV DVR = 16gb Archos 5 with Snap on DVR adapter crd Aircraft - General - Miscellaneous (FS/W) 3 Aug 31, 2010 11:48 PM
Discussion Piano DVR stops recording randomly Craig9080 FPV Talk 14 Feb 03, 2010 04:34 PM
