man I was just catching up with this thread when I read this.. i have done exactly this and I recognised it as soon as I read it.... but it was too late you had already figured it out.... the servo's twitch like they are working when you do the acc calibration just like you say.. then nothing happens.... anyway good show! sorry I did not read your post earlier.
Steve |
It's been a while since i have been on RCGroups, so i thought i should give an update.
Firstly the carbon 12x38 props are tested and now being finished, our first production run should be here around next week. Still not clear on price, but at a guess around 50 Aus per set, 1xcw and 1xccw. I won't go into how great they are just now, i can say they are a massive improvement over the plastic apc's. Other things we have been testing are Coaxial machines, X8 and Y6. Both machines fly very well, the new Russian frames that we have been buying are just awesome and at a fair price. They are so solid and fold up to nothing Here is a trailer of the Y-6 in action.
Cheers for now Simon |
EDIT: They look like the RC Carbon frames, yes? |
Has anyone dealt with a dead 2.1 FC board?
I have no LEDs, the buzzer on full time, no response on MKTools and the ATMega a little warmer than normal. I'm not sure how this happened (yet), and I'm not convinced that I received a dead board brand new. The MK guys claim they do test each board before it is sent out (not sure how as their don't solder on the debug pins). So, we are at a he said/she said discussion. It seems like the ATMega might be dead, and I can change that if I have to (once I order 1 or 2). I guess I could try reloading the firmware on the programming ports if required. If anyone has been down this road, I'm open for suggestions. |
Good to hear from you. I was starting to wonder where everybody had gone. The usual suspects have not been around much recently. I checked your site to get more info on the russian frames, but without much success (or did I miss something?). Can you give us more details, please? Cheers, Frederic |
Hi Frederic ,
They will be these frames from Sergey www.rc-carbon.com Quote:
I am going to make a big octo on which your props sould fit very well I am waiting for the first big Octo from Sergey this next week Cheers Maximus ps: take care of hard landing with the Hexa frame...even the new one has sensitive part (last curve near the aluminium tube is still too thin...) |
What are people using for OSD's on their MK's? I see the EPI osd at NGHobbies but can other OSD's use the MKGPS signal?
A dead CPU was what I was thinking as well. If you've got power to it, with no LEDs, and full time beeper, it's likely a goner. I'm guessing you don't see anything in the terminal window on MK-Tool when you power it up either? I'd try loading software, but that likely won't work. After that, you'd need to load the bootloader, but that can only be done with soldering equipment these days Rusty (work sucks) |
(new edition frames, no tubes, nice) Yip Carbon props are tested, batch should be ready in a week, 2 max! Price as low as we can, they could end up only costing 40 aus per set We have some other props coming out too Will let you guys know first! Simon |
Reason: new edition
Hello guys !
I am about to buy parts to build a heavy quad/ocot and as a pure novice I would really appreciate some quick feedback from experienced guys like you ! Please take a look if you can https://www.rcgroups.com/forums/show....php?t=1384101 Thanks in advance ! And I hope to post a first fligh video within a month ! Alain |
Thread Tools | |
Similar Threads | |||||
Discussion | Mikrokopter Okto 2 build | Roger_IIT | Multirotor Drone Talk | 6 | Feb 03, 2011 09:22 AM |
Discussion | Mikrokopter ME 2.0 Okto Build | robin4 | Multirotor Drone Talk | 16 | Jan 12, 2011 03:07 PM |
Discussion | Mikrokopter / UAVP / quadrocopter / quadrotor build | Arthur P. | Multirotor Drone Talk | 16696 | Nov 10, 2010 05:49 PM |
Discussion | X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion PART 2 | tend2it | Multirotor Drone Talk | 2203 | Nov 08, 2008 09:23 PM |
