This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Nov 09, 2010, 07:05 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Build Log
T-45 Goshawk (BAe Hawk) (90mm) by CMP
I just received this new CMP / CMpro T-45 arf, I have the CMP Spitfire and I like it ...
This thread in German or Italian
It is almost identical to the Hobbyking Hawk (also made by CMP or China Model Products : http://www.cmpairplane.com/ ) up to the paint
http://www.nitroplanes.com/cmpfitedfjet.html
http://www.hobbyking.com/hobbyking/s...40mm_ARF_.html
http://www.scaleflying.com/BAE-HAWK-...F-_p_2506.html
http://hobbyfly.de/en/rc-airplanes-1...40mm-6685.html
The Spit is a bit on the heavy side , but it seems now this Hawk is made relatively light(er) ...
The wing area on the T-45 is 24dm^2, so that makes the wing +33% larger in surface than the Sapac T-45.
Wingspan = 114 cm = 46 ''
Length = 122 cm = 49 ''
Wing area = 24 dm^2 = 372 sq in
Approximate scale 1:9
Est. weight rtf 7.2 - 8.0 lbs
CORRECT CG AFTER ONE YEAR OF FLYING:
ca. 110-115 mm from wing leading edge at root (see picture below)
Short video (8S, HET fan) Dec. 2011 (more T-45 videos on youtube under user "Herbzqy" )
T-45 Goshawk 90mm EDF by CMP (Neu 1515 on 8S) (3 min 0 sec)
Short video (6S, WeMoTec fan) Nov. 2011:
T-45 Hawk 90mm by CMP (BAe Hawk) Aerobatics (3 min 22 sec)
Old Nov 09, 2010, 07:06 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
This might be the first plane for my venture into 90mm EDF. Love to see what you do with it Herb...
Old Nov 09, 2010, 07:38 PM
Herb is offline
Lithium Member
Herb's Avatar
Steph, you will like it ... Big fuse with a small wing though
The upside is that there's no painting to do ...
Old Nov 09, 2010, 07:47 PM
Herb is offline
Lithium Member
Herb's Avatar
I did weigh all the components, the FG fuse is by far the heaviest part.
The wing & tail surfaces are very light
wing : 10.4 oz
fuse 32.8 oz
canopy 2.8 oz
fairing 1.0 oz
ducts 7.0 oz
droptank 2.3 oz
tail surfaces 1.4 oz
ventral fin 1.2 oz
misc. parts 7.0 oz (incl. fixed l.g. / wheels!)
Empty bare frame w/o gear & electronics = 58 oz = 3.65 lbs = 1.63 kg
I think I will save some weight by omitting droptanks, ventral fin & fairing
Old Nov 09, 2010, 07:58 PM
Herb is offline
Lithium Member
Herb's Avatar
The intake area is around 63.2 sq cm, so that's 124% of a DS-51 fan fsa.
For a 90mm fan they could have made the intakes a bit smaller
The WeMotec Midifan fits perfectly, I wish a Neu 1515 (edf, open case) would fit in it, I might have to go the HY shroud route again to get the Neu to fit.
Old Nov 09, 2010, 08:09 PM
Herb is offline
Lithium Member
Herb's Avatar
The inside is well done, plenty of ply reinforcements to keep the fuse rigid.
The reinforcements are - as usual in these kind of kits - glued in with some sort of hotglue.
There is a ton of space for batteries, but ultimately the battery size is of course determined by what kind of weight that small wing can carry
... 12S 5000 oh yes of course
Old Nov 09, 2010, 08:14 PM
Herb is offline
Lithium Member
Herb's Avatar
The wing is well made and very light (10oz) ... There's servo hatches for both ailerons & flaps.
Add a lot of un-needed weight to this plane & the retracts will come out the other side of the wing on a hard landing ...
Old Nov 09, 2010, 08:19 PM
Herb is offline
Lithium Member
Herb's Avatar
Size comparison with the Sapac Hawk / T-45 , a bit bigger but not by a whole lot ...
Old Nov 09, 2010, 08:24 PM
Herb is offline
Lithium Member
Herb's Avatar
One of the strong points of this kit is - besides the price - the nice finish on the fuse & wings - not much painting to do, unless you want a Bae Red Arrows Hawk instead
Old Nov 09, 2010, 09:47 PM
keith b is offline
Find More Posts by keith b
Herb since your not going to use the drop tank ventral fin and hook and hatch would you be interested in selling those items to me for another project.
Please PM me
Keith
Old Nov 10, 2010, 12:01 AM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
thanks Herb for doing this .great pics
Old Nov 10, 2010, 12:04 AM
Steph280 is offline
1.21 Gigawatts!
Steph280's Avatar
Herb what retracts do you plane to use for the 'smooth' runway of Fairview?
deltas are cool
AIR SALLY's Avatar
Tam Jets has a shroud that fits the midi rotor and the 1515 motor ...kinda pricey but it has a built in heat sink to protec your motor investment ...he also has one to fit the 1415 motor....which now come standard with cooling holes
Old Nov 10, 2010, 02:11 PM
Herb is offline
Lithium Member
Herb's Avatar
Rodger, yes the ducst have seams.
They are surprisingly well made, comparable to some of the best I have seen.
As I said, the only possible issue is perhaps that they are very light and there could be inevitably someone - perhaps without a whatmeter - that will eventually manage to implode them with a loud bang
keith b is offline
Hello Herb waiting to see your build and very interested in those parts your not going to use please let me know about those.Im sure this one will fit right in with the rest of your great looking planes.
Keith
Question CMPro T-45? gp125racer Nitro Planes 5 Dec 22, 2010 07:42 PM
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 01:24 PM
Discussion Im In love with this T-45 Goshawk mikes68charger Electric Ducted Fan Jet Talk 3 Nov 06, 2010 01:23 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 11:54 PM
Off Site Sapac T-45 Goshawk Composite TokageWeasel Aircraft - Electric - Jets (FS/W) 3 Oct 06, 2010 11:24 PM
