This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Nov 17, 2016, 12:27 PM
Lithium Member
Herb's Avatar
Have you looked here : ?
https://hobbyking.com/en_us/hardware...ts/wheels.html
http://www3.towerhobbies.com/cgi-bin/WTI0297p?C=QD
https://www.motionrc.com/pages/searc...q=dubro+wheels
I have quite an assortment of old and new wheels, so there's always something that fits ...
Nov 17, 2016, 12:41 PM
FLJetFlyer's Avatar
yesterday I ordered some of the Turnigy wheels from Hobby King.
the original CMP wheels looked very cool. but no one is selling them anymore.
thanks for the links Herb!
G
Dec 01, 2016, 12:04 PM
clsink1128
clsink1128's Avatar
I just got a CMP T-45 Goshawk from a friend of mine. The box never been opened. After opening the box everything seemed to be there and in good shape except no instruction manual. After downloading a set from nitro planes I realized it says nothing about what electronics is recommended for this project. My question is, what motor, fan unit, ESC, and battery set up would you recommend. I would rather get everything I need before I start my build. Thnx
Dec 01, 2016, 12:14 PM
A lightly built 6s 4400/5000mah Wemo setup with Eflite 15-25 retracts (?) and 100A ESC flies very well. I'm certain a 6s JetFan 90 setup would fly even better.
Dec 01, 2016, 01:04 PM
Lithium Member
Herb's Avatar
Wemo or Jetfan ... They would fly the same though, no reason to believe one will fly it better than the other
Dec 01, 2016, 01:50 PM
clsink1128
clsink1128's Avatar
Is that with a 1400-1500 kv. I have a flyfly 1500kv, a Turnigy dlux 100amp esc, and a 12 blade changesun 90mm fan unit on hand. Will any of those work for this plane with 3 4000mAh 3s. Sorry bout all the questions, this is my first actual build. I usually buy my planes that are RTFs
Dec 01, 2016, 02:14 PM
mavdriver's Avatar
So you are thinking 9s total ? it will fly it but is going to be heavy this plane flys great on 6s or 7s keep it lite as the landings could hurt the plane might have to reinforce the landing gear wells , I remember a few posts back guys were complaining the landing gear wells are weak and the landing gear was breaking out , Herb would probably give some good feedback on this .
Dec 01, 2016, 03:08 PM
clsink1128
clsink1128's Avatar
Thanks for the tip. That's why I'm here, trying to get all the info I can about this plane before I start the build. I want to get it right the first time and not have to go back in and redo mistakes. Rather be flying than repairing.
Dec 02, 2016, 11:32 PM
FLJetFlyer's Avatar
From what I read Herb reinforced the wheel hubs with heavy fiberglass.
I am currently building mine and I have some spare carbon fiber that I am gonna use to reinforce that area.
Although my build should be on the light side as it will be a 6s setup
Dec 03, 2016, 01:32 PM
Lithium Member
Herb's Avatar
No it will not work. It is too heavy. This jet flies well on a 6S 4000-5000's setup, using a good quality LIGHTweight fan such as the WeMoTec MidiFan EVO90mm, the JetFan 90mm or similar (some chinese fans are lighter than others). The 12-bl CS fan is way too HEAVY for the T-45.
Dec 13, 2016, 03:51 PM
clsink1128
clsink1128's Avatar
Thnx
Mar 15, 2017, 04:51 PM
Team Futaba
Devin McGRath's Avatar
Hey guys sorry to revive this old thread.
I have done a lot of searching and even more reading. I have had one of these sitting on the sheft for a few years, it was won in a raffle and finally decided its time to put it together. I have found most of the information on servo size, CG, Gear options and I think I have come to a conclusion of how im going to set her up.
I'm thinking of leaving the Gear off and bungee launching it, reason being I have a bunch of 6s 3850mah packs and I think I can get it light enough to fly pretty well on this pack if I leave the gear off. My only question at this point is what fan and motor do you guys think would be a good combination with a 70c Thunder Power 6s 3850?
Thank you and once again I'm sorry for reviving an old thread.
Devin McGrath
Mar 17, 2017, 02:03 PM
Lithium Member
Herb's Avatar
Originally Posted by Devin McGRath
... what fan and motor do you guys think would be a good combination with a 70c Thunder Power 6s 3850? ...
WeMoTec MidiFan EVO 90mm or similar,
http://www.effluxrc.com/WeMoTec-90mm...F-mfpEVO90.htm
and HK SK3 1900kv motor, or similar
https://hobbyking.com/en_us/turnigy-...-90mm-edf.html
These are just two suggestions, and similar setups (decent lightweight fan + decent inrunner motor) could work just as well, on 6S.
Here is how the above setup flew my old "Proedf" MiG-15 (sorry for the bad quality, it was taken by a friend with a phone) :
MiG-15 90mm composite EDF (HK/ProEdf/ProDesign) (1 min 53 sec)
and here is how the exact same setup flies my FlyFly Mirage :
Mirage 2000 by FlyFly 90mm EDF (2 min 14 sec)
Hope this helps ...
Mar 18, 2017, 12:31 AM
Team Futaba
Herb,
Thank you for the information. that is exactly waht i was looking for.
Devin McGrath
Mar 20, 2017, 12:59 PM
Lithium Member
Herb's Avatar
Afrer six years of faithful service I decided to retire my CMP T-45 ...
Lately I have not been flying it that often .... It started to have multiple issues that I did not feel I wanted to fix : The covering on the wings is quite yellow, I am getting tired of air retracts with a need to bring a pump, the old WeMo 6-blader should have been replaced with a WeMoTec EVO 11-blader, the T-45 fuse is heavy etc etc. Plus I really need the space in my garage.
So I took out all the electronics fan etc. which will go in a new airframe (with electric retracts).
Question CMPro T-45? gp125racer Vendor Talk 5 Dec 22, 2010 07:42 PM
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 01:24 PM
Discussion Im In love with this T-45 Goshawk mikes68charger Electric Ducted Fan Jet Talk 3 Nov 06, 2010 12:23 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Off Site Sapac T-45 Goshawk Composite TokageWeasel Aircraft - Electric - Jets (FS/W) 3 Oct 06, 2010 10:24 PM
