Sep 10, 2019, 08:12 AM
Originally Posted by pmackenzie
Looks like a Castle Phoenix 45 amp ESC to me.
https://www.bphobbies.com/view.asp?i...92&pid=U941640
Good spot Pat
I have a CC 45 and it looks the same - you can just about see the "CASTLE CREMATIONS" wording on the battery leads when you look for it now that I know it's there ...
Sep 15, 2019, 02:41 AM
gimbleguy's Avatar
Blue Bird BMS 127WV servos
I just done a quick servo speed test on these servo, using the Tarot ZYX programmer. My Batts has been on storage mode for a very long time also they are really old. Probably not the best candidates to use. Also my HW 60A V4 ESC is only rated to go at a max 8V instead of 8.4V which the manufacturer recommends.
Anyways you can see on the pics, they seem to be fast. Also no slop. I can't wait to try them on my TRex 250(cyclics) and 450PRO(cyclics), X360 (cyclics+tail), and Trex 470L(cyclics+tail)
BMS 127WV High Voltage Servo (1 min 3 sec)
Thank you to Atomic Skull for recommending me these servos
Sep 18, 2019, 10:27 AM
Turnigynarian
2Doggs's Avatar
Looks promising
That seems to tally quite well with the claimed spec of 0.05s. I used to use a similar CX program box as a servo tester, until it quit working one day.. Always had to run the speed tests a few times, and use an average since results were quite variable.
It looks like a promising servo for small helis, 450's even, though the mounting lugs on the nylon case looks a bit fragile. Should be fine on a heli tail, though, and it's a lot lighter than the KST115/215 servos.
Sep 18, 2019, 12:23 PM
If it Works, You Better Fix It
VelocityRC's Avatar
That was my thought when he posted using on a 470L and the X360 ??
Perhaps a follow up post after trying them out for a bit ??
Bill S.
Sep 18, 2019, 05:15 PM
Just looking at the pic, it would seem to be the ultra micro size, maybe a bit small?
Sep 18, 2019, 06:08 PM
gimbleguy's Avatar
It should be fine, this servo reminds me of the old Turnigy DS480. The only problem with that servo was that it was easy to fry with a slight over voltage. As you can see my ESC is set to 8V, but it is going higher than 8V. So in a way I'm glad my ESC doesn't do 8.4V as it may fry the servo. But on the other hand I would like to see if this BMS servo would be able to handle slightly higher than 8.4V and will it fry or not?
https://hobbyking.com/en_us/turnigy-...___store=en_us
Specifications:
Operating Voltage: 4.8~5.0V
Torque: 4.8V/ 1.85 Kg.cm
Speed: 0.068s/60°
Gear Type: All Metal Gears
Weight: 10.9g
APPLY WITH 200~450 SMALL HELICOPTER USE
Glider Digital servo (Apply to the 10mm slim wings of glider)
Apply to the 12~18 cm Robot
Sep 18, 2019, 07:24 PM
gimbleguy's Avatar
Curiosity got the best of me. I wanted to see if the BMS 127WV servo can handle 8.4V. Seems to work fine
Sep 18, 2019, 08:30 PM
gimbleguy's Avatar
Hobbyking 20A Watt Meter
I thought I'd test out my old HK 20A Watt meter since I already have a servo to test. It seems like it's not that precise on reading low current.
Hobbyking 20A Watt Meter (2 min 5 sec)
Sep 21, 2019, 11:14 AM
rc user
pdooley's Avatar
this is interesting, i guess BG got a hold of some KDS 450's.
https://www.banggood.com/KDS-450SV-F...r_warehouse=CN
i see them on ebay too.
Sep 22, 2019, 10:16 PM
rc user
pdooley's Avatar
Forced Induction 450
crap picture and description, 0 seller rating.
seems legit.
https://www.ebay.com/itm/align-trex-...4383.l4275.c10
Sep 29, 2019, 12:54 PM
rc user
pdooley's Avatar
here's an oldie but goodie, doing surprising well in the bidding. at least for the seller..
https://www.ebay.com/itm/20278423535...&ul_noapp=true
Sep 29, 2019, 02:14 PM
gimbleguy's Avatar
Interesting... that there is still a demand for FB helis
Sep 29, 2019, 03:12 PM
Uh, if that's the way his local hobby shop runs wiring, he'd better find another hobby shop!
Sep 29, 2019, 07:27 PM
rc user
pdooley's Avatar
looks like something I'd do
Sep 30, 2019, 04:06 AM
gimbleguy's Avatar
Though I personally think everyone should wire their heli to their liking.
But if you're paying top dollar to a hobby shop to build your heli, I can see Pa Flyer's point of view.
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 11:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
