Nov 03, 2010, 01:54 PM
Parkzone UM P-51D motor current and battery
Hi,
Does anyone know the motor current of this airplane? I have watt meter, but never thought about to check the airplane this small. I bought several 138 mah 10C batteries for HK for only $0.99/each, but the life time were very short (3 to 5 charge cycles), then totally dead. I also bought several 160 mah 30C from HK. Their life are much longer. I wonder that 10C is too small of discharge rate, and the reason for shorted battery life.
Xiaoyu,
Nov 03, 2010, 03:20 PM
yes, 10c is too little for PZ ump51 - also those Hk 1gen batts are really bad in ump51 and others with same motor. poor quality...
the nanotech' work well but good luck getting those - other wise its the spendy stuff like hyperions that most ppl use or buy zippy and get plugs is another option- I'd rather wait then pay $8 for a single cell lipo!
Nov 03, 2010, 03:47 PM
Micro's all the way!!!!
VTOLrc's Avatar
yeah I did a check once and from what I saw the motor pulls about 1.1 Amps so.................
Nov 03, 2010, 04:10 PM
[email protected] should have enough discharge capacity for 1.1A. The battery must has lower rate than 10C. I have very good luck for HK 160 mah 30C ($1.69 each. With $2.99 shipping, you can buy 6 of them). I bought several times for filling the extra available weight when I bought other items. They were all good. I got more than 10 minutes flight time for P-51. They are also fit indoor heli and Ember2 well. For Ember2, the flight time may reach 25 to 30minutes.
Nov 03, 2010, 04:28 PM
Way to many airplanes!
I checked the whole airplane (Rx and servos included) and I got reading between 1.6amps and 1.9amps.... At 1.9amps, the motor died not long after. So I'm thinking 1.6 amps is probably right.
Nov 03, 2010, 05:54 PM
Did you mean that you could kill the motor by full throttle with 3.7 v 1S battery?
Nov 03, 2010, 06:03 PM
Power Wheels Guru
UNGN's Avatar
The 138 Flightmax batteries from HK won't fly a Mustang. They are a phony baloney 138 and aren't as good as a Parkzone 110.
Nov 04, 2010, 08:28 PM
I as lucky and got the nano-tech batterys. I have the turnigy 160 also. If you can get the nano-techs you will notice a difference. Just my 2cts.
Discussion brushless motor for parkzone um p 51 ultra stick Scratchbuilt Indoor and Micro Models 15 Nov 26, 2010 01:50 PM
Found Parkzone UM Sukhoi 26m Motor Trade for UM P-51 Motor microflitedude Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Nov 08, 2010 02:56 AM
Sold Parkzone P-51D Mustang Bind n Fly With Extras! Torx Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Oct 14, 2010 11:07 AM
Sold UM P-51D AR6400 Brick + AS2000 Servo + Motor/Prop & Extra's queadlunnrau Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Jul 01, 2010 12:44 AM
