Icon A5 build
maybe this should be in the waterplanes thread.
anyways, here is my icon a5 so far. ~afitz87 |
yeah there are plans. this is the link to original https://www.rcgroups.com/forums/show...=icon+a5+build
the plans are not exact. You have to get a little creative with a few parts. the plans give you 75% of the build. |
got some more work done on the fuselage. i'm having some problems with the motor mount/wing assembly. i don't think having a removable wing is structurally possible? i'm open to ideas.
i ended up cutting off the motor mount. instead of having the wing slide in, below the motor, i may end up gluing the motor mount to the top of the wing. |
subscribed. It looks nice.
Is that black foam depron? The black 6mm depron I had was really hard to cut so neatly. how did you do it? |
i've noticed that too. it also seems slightly more flexible than the white depron. i have a an ultra fine flat stone that i use to re-sharpen spent exacto blades. you have to cut slow. retrace each cut with light pressure and sharpen the blade often. cut in maybe slightly more than 0.5mm with each stroke. |
Ahh.Thanks. I onlly have a fairly coarse blade stone. Cool
Get one of these... this has saved me hundreds in Exacto blades. It is called a Pocket Pal Crock Stick. Google it. Walmart has a similar thing, but you will have to modify it to use it on Exacto blades. Sorry about the resolution, but my camera doesn't do closeups very well.
ahhh.. I've seen those before. I Might get one. But, when I searched it up just now, I couldn't find it? Walmart's search doesn't have it,, and there are no shopping results for it on Google. Did you spell it right?
Here is a link to one... it's blue, but the same thing.
http://www.sharpenem.com/Ceramic-And...cket-Sharpener |
That must be pretty hard on the wallet
Thread Tools | |
Similar Threads | |||||
Discussion | Icon A5 (real airplane) | zaguruinzasky | FPV Aircraft | 34 | Dec 24, 2010 01:59 PM |
Discussion | Interesting new LSA amphibian in the works: The Icon A5 | Thomas B | Waterplanes | 30 | May 14, 2010 02:00 AM |
Build Log | ICON-A5 RC build with PET sheet and PUF | gocarina | Waterplanes | 5 | Mar 26, 2010 02:04 PM |
Discussion | Icon A5 | EliasRR | Mexico | 4 | Aug 02, 2009 02:33 AM |
