Oct 29, 2010, 09:40 AM
rc blimp manufacturer
powerblimp's Avatar
Alert
DLE 110 - 111 problems see pictures!!!
hello i have a problem with my DLE 110..
the prop shaft is almost broken!
does anyone of you got the same problem .. after 40 min of run!
Oct 29, 2010, 11:14 AM
-insert witty saying here-
Hemikiller's Avatar
Looks like there's an updated prop hub, guess the original design didn't work out so well...
http://www3.towerhobbies.com/cgi-bin...?&I=LXYNF9&P=Z
Oct 29, 2010, 11:12 PM
Old coot's Avatar
By a couple of your pic`s looks like that clamp you have on the front of the crank case was rubbing on the hub also. May want to check that with the new one.
Nov 03, 2010, 04:28 AM
powerblimp's Avatar
thank you ery much
the champ did not touch it is a 0.5mm gap and there is no mark on hub
but the new hub is a good solution.. i think aluminium was affected with impurty and was really weak..
Nov 03, 2010, 06:31 AM
Chinese metalurgy
Originally Posted by powerblimp
thank you ery much
WOW impurity in a chinese made engine? could that be?
Build Log Building MK Okto FC 2.0 - Now with 111 pictures drhswe Multirotor Drone Talk 18 Oct 20, 2010 01:53 PM
Discussion Need DLE 111 CAD file HotdogX Scale Sailplanes 9 Oct 04, 2010 08:14 PM
Found DLE 111 Mufflers DaOldGuy Aircraft - Fuel - Engines and Accessories (FS/W) 3 Oct 04, 2010 03:21 PM
Discussion Need DLE 111 CAD File HotdogX Engines 0 Oct 02, 2010 04:55 PM
Sold Nib dle 111 fabmaster911 Aircraft - Fuel - Engines and Accessories (FS/W) 5 Dec 17, 2009 02:41 AM
