Yes that will be fine.
Go to the tips thread for the VMX and read about the blueprinting you can do to tune up the forks.
Yup, Do that, but first try this> Loosen the 2 bolts on the bottom of the fork legs that clamp the axles, the stroke the forks fully up a few times, THEN while holding the forks fully compressed tighten the the 2 bolts back up. See if that helps, if not do the blue printing proceedure. Good Luck,
Wow! 146 pages and I can honestly say I've read them all, almost sad to be done reading. I just picked one of these cool bikes up and want to thanks Venom..ie Chris and everyone that have taken the time to help everyone out..this is what this hobby is about, helping each other, I've owned a few other Venom products and all I can say is they stand behind their product and Customer Service is second to none! I'm looking forward to a fun and sucessful set up on my new VMX...all because of everybody on this forum and Chris! Thank you!!
Mach 1 |
Your welcome and thanks for posting that it means a lot to us here at Venom!
Chris |
Hey Chris, quick question for you....dug into the rear wheel to make sure all was good, could not get into the clutch to check the adjustment because 2 of the hex (allen) heads on two of the flywheel cover bolts had been rounded out right from the start. I tried all my own hex wrenches also and none of them would even bite, I did manage to get the other two of them loose...any ideas?
Thanks in advance! 70 Mach |
Same as above, Dremel a slot then use a screw driver. Sorry about that let me know if you find any other build issues.
Chris |
Lets see after about 6 time out with this bike I have had to replace the gyro gears,the sprocket set screw came loose and it is a son of a gun to get to, I finaly drilled a hole and can get to it now,,,the gear on the side is now smooth and needs replacing,not in stock so far, the forks need to be worked on, they dont go up and down, maybe needs new oil or something,chain has come off a couple time even with it readjusted, man I work on this more than my old Harley, good thing I can fix things or I would have a $450.00 paper weight. Broken again right now and am just about tired of fixing it EVERYTIME I take it out to run. Oh ya who ever assembled this at the factory must have missed the instruction on how not to over tighten ALL the screws, see they only go into plastic and when they are over tightened they strip, been trying to get by putting super glue in the holes to get some of the important stress points to tighten up, So far my opion of this bike is,,,, when running it is cool to drive, but it has broke down more time than I can believe. I wish I had the $450.00 of my hard earned money back.
Bumbed out owner |
Hey Blade sorry your bummed out maybe I can help sort things out with you.
Where have you been driving your bike at? Off road or street, grass, gravel? Which part numbers do you need, PM me a list let me see whats in stock now. Are you in the US? Chris |
Thread Tools | |
Similar Threads | |||||
Discussion | HoobyKing new dirt bike vs. venom vmx 450 | amitgv1 | Motorcycles | 19 | Oct 13, 2010 11:09 AM |
Discussion | Duratrax DX450 VS. Venom VMX 450 | Butters | Motorcycles | 31 | Mar 18, 2010 03:41 PM |
VMX 1/4 Scale Dirt Bike | Venom Media | Batteries and Chargers | 4 | Mar 01, 2010 07:41 PM | |
Discussion | Venom VMX 450 MX Bike! | Mark Headling | Motorcycles | 2 | Feb 09, 2010 12:44 PM |
Discussion | The Original 1/4 Scale RC nitro dirt bike from the 70's | Magicd1 | Motorcycles | 6 | Oct 02, 2006 02:06 AM |
